LM5 BTL Certified
I have used LM5 as a bacnet gateway and have not had any issues.
But now there are some text in a contract that i am wondering if the LM5 can do. Text is as follows:
Device should support BACnet Standardized Device Profile (Annex L).
It should be used BIBB's standard for B-BC på BACnet IP, or B-AAC  or B-ASC on
BACnet MS/TP.
- BACnet units should be BTL-sertified. Should be documented with BACnet PICS, or a certicicat that confirms to BIBB`s.
-The unit should adoptble to exciting sites with changeble Bacnet device ID and UDP port.
-The unit should support BACnet encoding type ISO 10646 (UCS-2) / ANSI X3.4
(US-ASCII), that is changeble after installation. Equipment on BACnet IP should also suppport BBMD.
If you need the cert itself you can use the SE version spaceLYnk. They certified the stack, We use exactly the same but no paper.
We don't support MS/TP
I guess that it will never be asked about it. But then i know that it excist.
The rest is also ok, ?
It will be bacnet ip so lack of support for ms/tp is ok.
Check yourself
https://www.bacnetinternational.net/cata...meLYnk.pdf
Perfect.
Tried searching for it. But i was looking for the LM5.
Thanks Daniel..
