NetAtmo Cameras into LM
Hello, I want to integrate several NetAtmo security cameras in LM, to read the events of the cameras, for example if I detect movement, turn on a light.
Has anyone been able to integrate NetAtmo cameras into LM?
Thanks a lot.
NetAtmo has webhook option that allows sending events via HTTP: https://dev.netatmo.com/apidocumentation...y#webhooks
On LM side you need to create a server-side .lp script that will handle events. Script should be uploaded via FTP using apps login to the user directory. If the file name is netatmo.lp then the HTTP path will be http://user:password@LM_IP/user/netatmo.lp
If username/password access does not work then you can disable password protection for user directory in User access settings.
Use this as a starting point:
require('apps')
-- read POST data
body = ngx.req.get_body_data()
if body then
  -- decode data as JSON
  data = json.pdecode(body)
  -- check that data is a table
  if type(data) == 'table' then
    log(data)
    -- movement detected, you can check data.camera_id if you have multiple cameras
    if data.event_type == 'movement' then
      -- do something when movement happens
Thanks a lot.
I will investigate it.
Have you’ve been successful to get the Netatmo security cams running? I’ve a Netatmo doorbell to implement in LM.
Many thanks in advance!
Best Regards
Steffen
Hi All,
i have this working in part, i am getting messages if i change some settings on the netatmo app (log as below) but i am not getting messages on event from the camera, any ideas- must be a netatmo setting?
* table:
["change"]
* string: home_updated
["home"]
* table:
["id"]
* string: xxxxxxxxxxxxxxxxxxxxxx
["user_id"]
* string: xxxxxxxxxxxxxxxxxxxxxxxxx
["push_type"]
* string: topology_changed
["user"]
* table:
["email"]
["id"]
["home_id"]
Many Thanks
Most probably something is missing in the configuration on Netatmo side. LM is simply logging all received requests. It might be also possible that the JSON string is incorrect. Try logging the body variable contents:
require('apps')
-- read POST data
log(body)
(16.03.2022, 00:41)benanderson_475 Wrote: Hi All,
* table:
["change"]
["home"]
  * table:
  ["id"]
["user_id"]
["push_type"]
["user"]
  * table:
  ["email"]
  ["id"]
["home_id"]
Many Thanks
would it be possible to share the script with us?
I like to get it working as well!
Many thanks for your help!
Best Regards
Steffen
The script (.lp file) is here: https://forum.logicmachine.net/showthrea...4#pid19054
(16.03.2022, 09:24)admin Wrote: Most probably something is missing in the configuration on Netatmo side. LM is simply logging all received requests. It might be also possible that the JSON string is incorrect. Try logging the body variable contents:
require('apps')
-- read POST data
log(body)
Thanks, I added in the log(body), returns a string - same as decoded json
Looking into it, it seems this is broken on the Netatmo side, the camera I have is an outdoor camera “NOC” , it sends the smart events to the Netatmo app but not to the webhook… (but other events from the Netatmo web are sent to the webhook) just not the ones that are actually useful…  Huh
looks like it is a Netatmo firmware issue.
Has anyone else been successfully using this method? If so what camera/ and firmware version is being used?
I Thought i would update this post as it wasn't straight forward to get this working,
After i had uploaded by ftp to the LM the file netatmo.lp to apps,
I created an app on netatmo dev platform (https://dev.netatmo.com/apps/) and entered my Webhook url as
http://mydomain/user/netatmo.lp (this is redirected through my modem to the lan ip of the lm) i also take parameters client ID and client secret for later on
Firstly we need to pass username and password with the client id and secret with function and authorize lm use to this app we created on netatmo dev,
call the function Get_Token() once, this authorizes the lm to use the netatmo app
(as per netatmo doc, although this wasn't really clear that this was required in order to use webhooks etc)
The script writes the token, refresh token and expiry time in seconds to 3 different virtual object data type 250byte string
Then run the scheduled script to refresh the token, call function Refresh_token() once an hour.
now I receive all Smart events from the netatmo camera in the log from the netatmo.lp script
user library as below, change/add all credentials and virtual obj to suit
require 'ltn12'
require 'socket.http'
json = require("json")
https = require 'ssl.https'
  local client_id = "xxxxxxxxxxxxxxxxxxxxx"
  local client_secret = "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
  local scope = "read_presence read_camera"  --Welcome camera use read_camera, Presence camera use read_presence
  local username = "xxxxxxxxxxxxx"
  local password = "xxxxxxxxxxxxxxxxxxx"
--Client credentials grant type
  grant_acess_data = "grant_type=password&client_id=" .. client_id .."&client_secret=" .. client_secret .. "&username=" .. username .. "&password=" .. password .. "&scope=" .. scope
  request_oauth_url = "https://api.netatmo.net/oauth2/token"
function Netatmo_Post(url, body, headers) --headers = {}
   res_body ={}
  local body, code, hdrs, stat = https.request
    url = url;
    method = "POST",
    headers = headers,
    source = ltn12.source.string(body);
    sink = ltn12.sink.table(res_body);
  if (code ~= 200) then
    log("netatmo post error : "..tostring(code)..","..tostring(body))
    return
   return json.pdecode(res_body[1])
  res = Netatmo_Post(request_oauth_url, grant_acess_data, {["Content-Type"] = "application/x-www-form-urlencoded",  ["Content-Length"] = #grant_acess_data, })
--log(res)
  if res then
  grp.write('32/1/1', res.refresh_token)
  grp.write('32/1/2', res.access_token)
  grp.write('32/1/3', res.expires_in)
    log('Netatmo token request failed')
  refresh_acess_data = "grant_type=refresh_token&refresh_token="..grp.getvalue('32/1/1').."&client_id=" .. client_id .."&client_secret=" .. client_secret
  res = Netatmo_Post(request_oauth_url, refresh_acess_data , {["Content-Type"] = "application/x-www-form-urlencoded",  ["Content-Length"] = #refresh_acess_data, })
  log(res)
  if res then
    log('Netatmo token refresh failed')
