PID Regler
Hello
I wanted to know if with some scripts or in another way it is possible to have an internal controller in the LogicMachine, or if I have to create everything in a script?
thanks a lot
Have a look here
https://openrb.com/example-pid-thermostat-with-lm2/
(25.11.2020, 12:36)Daniel. Wrote: Have a look here
I hae see and now i write this code is correct for 3 PID ?
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950515253545556575859606162
-- PID VENTILAZIONE SERRA 7     -- init pid algorithm     if not p1 then       p1 = PID:init({         current = '32/1/22',         setpoint = '32/1/10',         -- VEDERE COSA FARE CON            -- USCITA PILOTA ENTRAMBI AEREOTERMO ?           output = '32/1/13',       min = 5,       max = 50,       manual = '32/1/19',       --inverted ='nn/n/nn',         kp = 1, -- BANDA PROPORZIONALE       ki = 10    -- INTEGRALE       --kd = 1  -- DERIVATIVA     })     end     -- run algorithm     p1:run() -- PID VENTILAZIONE SERRA 8     -- init pid algorithm     if not p2 then       p2 = PID:init({         current = '32/1/23',         setpoint = '32/1/11',         -- VEDERE COSA FARE CON            -- USCITA PILOTA ENTRAMBI AEREOTERMO ?           output = '32/1/14',       min = 5,       max = 50,       manual = '32/1/20',       --inverted ='nn/n/nn',         kp = 1, -- BANDA PROPORZIONALE       ki = 10    -- INTEGRALE       --kd = 1  -- DERIVATIVA     })     end     -- run algorithm     p2:run() -- PID VENTILAZIONE SERRA 9     -- init pid algorithm     if not p3 then       p3 = PID:init({         current = '32/1/24',         setpoint = '32/1/12',         -- VEDERE COSA FARE CON            -- USCITA PILOTA ENTRAMBI AEREOTERMO ?           output = '32/1/15',       min = 5,       max = 50,       manual = '32/1/21',       --inverted ='nn/n/nn',         kp = 0.5, -- BANDA PROPORZIONALE       ki = 10    -- INTEGRALE       --kd = 1  -- DERIVATIVA     })     end     -- run algorithm     p3:run()
Tank's
Like this
https://forum.logicmachine.net/showthrea...0#pid18790
