SNMP control of APC PDU
I'd like to run the following SNMP command to power cycle the ports in an APC AP7920B PDU (port 8 in the example below)
snmpset -c private 192.168.1.100 1.3.6.1.4.1.318.1.1.12.3.3.1.1.4.8 integer 3
The  SNMP set command works from the terminal but I'm having some trouble running this from my script in LogicMachine.
Here's what I have so far
require('snmp')
conn, err = snmp.open({
  version = snmp.SNMPv1,
  community = "private",
  port = 161,
  peer = "192.168.1.100",
assert(conn, err)
vbind, err = conn:set("1.3.6.1.4.1.318.1.1.12.3.3.1.1.4.8 integer 3")
I'm getting the following error trying to load the SNMP library on my CBUS 5500SHAC (which runs LM) - is there a way that I can load the SNMP library?
[color=#000000][size=small][font=Consolas, monospace]module 'snmp' not found:
no field package.preload['snmp']
no file './snmp'
no file 'Library snmp'
no file 'Library snmp.so'[/font][/size][/color]
Many thanks in advance.
James
Check PM
