Threads: 67
Hello.
I'm writing av script to read several values from different GA and comparing all of these values to get the highest of them as an output.
I can structure the GA's so that they come with increment of +1.
Any tips from people who have done this before?
-Regards
Why not use tags? You can get values for all objects with a single function call this way.
Threads: 67
Oh, I did not know.
Could you give an example?
Sent fra min SM-G980F via Tapatalk
Threads: 67
works perfekt, thank you!
Threads: 67
Spinoff on this post.
Here we use tags to calculate the max value. Is there any clever way to disregard a value if a GA is "true"? I want to check if the damper is in faultstate before running the "max"script.
Threads: 35
Threads: 67
i don't think that will work. There is one fault GA for each damper, and I only want to dismiss the value from that one damper. Is it possible to alter tags on GAs from script?
Do you mean that you want to check another status object before including value in the calculation? In this case you need some addressing rules so you can get status object address for another tagged object.
