Scene APP/Scene config
Can anone explain how the scene manager and the scene config app is intended to work? Big Grin
I am thinking, that the intension is that this should work outside the scenes in configurator...?
well.... I have tried to figured it out, but cant get the KNX objects in the [color=rgba(0, 0, 0, 0.87)]Sequence properties....to show...[/color]
Not sure this is a easy appfor dummies....
Thinking if wanted to sell the house...well, god luck without a system integrator for a easy task.. (should be easy at least)
SE- Is it possible to get this made easy??
GIA Big Grin
Best Regards
NewBee to wiser
You need to open the scene config, click on the plus sign to add allowed objects, this opens a dialog and click on the text “object”, you can type the group address / name or select an object from the list.
The allowed objects can now be used within the various scenes you can create in the scene app.
