Threads: 1
Hello, this seems very obvious but I can't seem to find any information on this. I see the setting where I can enable the http and https service and I have enabled them.
Now I have some Shelly Sensors (in the same network as the LM) that I can configure to send a GET request to a URL when certain tresholds are exceeded.
I thought this together with the http service would allow me to set an object in the LM via URL. But I can't find anywhere how the HTTP server is supposed to work.
Is this even possible?
Password cannot be disabled. Are you using "remote" username for this?
Threads: 1
That's a shame.
I figured out the sensors are doing something wrong and are locking the login due to 5 failed logon attempts (even though I set the user:password correctly in the url). I think I'll open an issue with the manufacturer and config them to go via IFTTT atm.
There's a solution with .lp file that will work without login/password, I'll post an example later.
Threads: 12
At least the communication with Shell is solved. Semms like the SSL certificate was the problem. I solved this by enabeling HTTP communication at the w4k und use a http instead of a httpS request.
Threads: 16
Hello team:
Is there any way to do something simple as "remote services" but using basic or digest authentication?
I have done it using write.lp file, but I have lose security.
Is there any easy way to connect two or more than two logicMachine with a secury and easy way?
best regards
Roger
Threads: 31
Use MQTT and this app makes it super simple.
https://forum.logicmachine.net/showthread.php?tid=5878
You will need Broker app on one of the LMs
