05.02.2021, 10:35
Hi all clever inmates.
I have a Hot tub (SPA) with a complete Balboa BP2100 SPA controller and TP800 control panel setup. I want to integrate this into the logicMachine world to give some logic to it. This could be of course be visualization, but also change settings from "eco mode - 32 degrees" to "ready mode 40 degrees" during peak and cheaper hours of the day. The last weeks electricity prices has really been dancing up and down by x5 factor.
At Github I see some few successful Balboa SPA hack cases, most through a RaspberryPi/Ardurinio route. I do not have knowledge of the Rpi/Ardinio hardware and were hoping that I could avoid moving to deep into that world.
FIRST: Is there anyone else who has connected their Balboa hot tub to their LogicMachine?
Can I connect the LogicMachine's RS channel directly to the SPA without risking killing the LogicMachine, or do I need to go through other devices - a different controller card or RaspberryPi route as descirbed? I already have a Modbus ventilation system on the Modbus of mye Logic Machine and I have ordered some PowerTags from Schneider to measure consumption at the heavy consumers.
Any advice on the matter would be highly appreciated.
EXAMPLE GITHUB BALBOA SPA PROJECTS
- [color=var(--color-text-link)]https://github.com/garbled1/balboa_homeassistan [/color]
- [color=var(--color-text-link)]https://github.com/garbled1/pybalboa[/color] - Python library for local spa control
- [color=var(--color-text-link)]https://github.com/plmilord/Hass.io-custom-component-spaclient[/color] - Another HASS custom component (and source of "spaclient" logos)
- [color=var(--color-text-link)]https://github.com/ccutrer/balboa_worldwide_app[/color] - Fountain of knowledge for most of the messages sent from the spa wifi module
- [color=var(--color-text-link)]https://github.com/natekspencer/BwaSpaManager[/color] - A SmartThings cloud-based solution
Schneider Wiser (homeLynk), Power Tags, DALI, Multitouch Pro, Panasonic Heating pump, Flexit balansed ventilation, HUE integration, Lemus Speaker system. Tibber integration.
