trigging with tag
I've 50 rooms at a hotel.
I made a script for one room. How do I trigger my script with a tag 'guest present' instead,  and then get the name of the triggede room and write to its current VAV? I want one script instead of 50.
Card switch 'XS2_425_C_D' indicates guest present,and got the tag 'guest present' (together with 50 other rooms). VAV should then go to a common set value '4/2/0'. VAV's name is similar to card switch 'VAV_2_425_SP'.
In the group 'VAV_2_425_REG' I have object from the regulator. This regulator will take over if it's greater than the set value(max comparator) and if guest is not present.
so far:
switch = grp.getvalue('XS2_425_C_D')
Comp_max_input1 = grp.getvalue('VAV_2_425_REG')
Comp_max_input2 = grp.getvalue('4/2/0')
Comp_max_output = 'VAV_2_425_SP'
if switch == true then
require('custom.fbeditor20.Math_advanced')
functions_Math_advanced_json_fbe_max_com_input_1 = Comp_max_input1
functions_Math_advanced_json_fbe_max_com_input_2 = Comp_max_input2
functions_Math_advanced_json_fbe_max_com_input_3 = nil
functions_Math_advanced_json_fbe_max_com_input_4 = nil
functions_Math_advanced_json_fbe_max_com_input_5 = nil
functions_Math_advanced_json_fbe_max_com_input_6 = nil
functions_Math_advanced_json_fbe_max_com_input_7 = nil
functions_Math_advanced_json_fbe_max_com_input_8 = nil
out = fbe_max_com(functions_Math_advanced_json_fbe_max_com_input_1, functions_Math_advanced_json_fbe_max_com_input_2, functions_Math_advanced_json_fbe_max_com_input_3, functions_Math_advanced_json_fbe_max_com_input_4, functions_Math_advanced_json_fbe_max_com_input_5, functions_Math_advanced_json_fbe_max_com_input_6, functions_Math_advanced_json_fbe_max_com_input_7, functions_Math_advanced_json_fbe_max_com_input_8, 'fb__Comparator__fbe_max_com__id')
grp.write(Comp_max_output, out)
grp.write(Comp_max_output, Comp_max_input1)
This one works, but only for room 2_425.
best regards Vidar
Hi here is example script which does what you ask for, you can convert yours same way.
--// when input = 1 then output (100%) ; when input = 0 then output (25%)
onValue = 255 -- remember that when object will have scale dpt then values are from 0-100
offValue = 64
----------------------------------------------Optional change-----------------------------------------------
PIR_name = 'PIR'
DALI_name = 'SetValue'
DaliOutName, found = string.gsub(grp.alias(event.dst), PIR_name, DALI_name)
myobject = grp.find(DaliOutName)
log(myobject)
if event.getvalue()  then
  if  found == 1 then
    if grp.find(DaliOutName) then   -- check if output group exists
          grp.write(DaliOutName, onValue) --//
      alert('Group address '..DaliOutName ..' does not exist' )
    alert('Group address has not correct name %s', event.dst)
  if found == 1 then
      grp.write(DaliOutName, offValue) --//
tnx, I'll try to figure it out
