Custom value select - Control Size Scale
I've seen that using chrome and android app the function "Control Size Scale" on "Custom value select" doesn't work...
It seems that the property  transform: scale is not inserted inside object properties. But if I add it manually inspecting the object it works...
I've tried it using Mozilla and it's working fine...
Is there any way to solve it when using app?
This is a known bug. As a temporary solution you can use Custom CSS and additional classes to scale controls.
(16.02.2021, 08:03)admin Wrote: This is a known bug. As a temporary solution you can use Custom CSS and additional classes to scale controls.
Done:
.popover.control-vselect {
  transform: scale(1.75)!important;
Thanks!
Done:
Thanks!
Hi, I've just seen that this solution changes the menu size of schedulers day selection, ...
Is there any way to apply it only to custom value selection menus on visualitzation?
Try this
.popover.control.control-vselect.show{
(06.04.2021, 15:41)Daniel. Wrote: Try this
Ok now it works!
Thanks!
