Modbus → Bacnet Gateway
Good afternoon;
What is the way to made a Modbus(TP)/Bacnet(IP) gateway with the logic machine ?
In this case, the logic machine poll any modbus meters and provide the value trough bacnet (server).
Best regard
You just have to make a profile of this modbus device, then map objects to it and export objects to bacnet.
(16.02.2021, 13:46)Daniel. Wrote: You just have to make a profile of this modbus device, then map objects to it and export objects to bacnet.
It's means that i have to use KNX objet (virtual or not) to transform Modbus to Bacnet ?
Yes, everything goes in LM trough objects even when KNX is not used.
