08.03.2021, 07:50
Is there an package for the imx28cpu to use zero tier like this
https://openrb.com/zerotier-remote-maintenance-of-lm5/
Zero tier
08.03.2021, 07:50
09.03.2021, 21:43
(This post was last modified: 09.03.2021, 21:44 by benanderson_475.)
(08.03.2021, 07:50)benanderson_475 Wrote: Is there an package for the imx28cpu to use zero tier like this 1457 views and nobody knows? i also tried https://openrb.com/zerotier-remote-maintenance-of-lm5/ on lm5 with imx6 cpu, i have installed the packages in step 6 but cannot find the Zero tier config option after installing the packages and rebooting, i confirm packages are installed, but step 9 as per above link, under services i cant find ZeroTier to enable it. 9. Go to System Configuration -> Services -> ZeroTier Must be something simple i am missing
10.03.2021, 09:23
Which LM do you have? You need new firmware.
10.03.2021, 09:52
10.03.2021, 09:59
Use this, http://dl.openrb.com/lm-20-imx6/lm5m3ex-20201111.img
You will have to install the packages again.
10.03.2021, 19:18
Is Zero Tier also with lm2i possible ?
10.03.2021, 19:28
We didn't compile this for old cpu, for now not.
10.03.2021, 20:38
(This post was last modified: 10.03.2021, 20:39 by benanderson_475.)
(10.03.2021, 09:59)Daniel. Wrote: Use this, http://dl.openrb.com/lm-20-imx6/lm5m3ex-20201111.img Thanks Daniel, i updated firmware as per link above and installed pkg again, i still not find the zero tier config tab after reboot
11.03.2021, 08:30
Clear browser cache
11.03.2021, 08:39
11.03.2021, 09:00
Is this firmware also suitable for LM5p2-KC?
11.03.2021, 09:02
Yes it is
