Threads: 84
hello
How could we connect IoT Products which compatible with the Tuya app with OUR LM, SL, HL?
is it possible and How.
regards.
Best Regards,
MQTT integration is the easiest solution by far
Threads: 1
Hello
I am trying to reach to my TUYA developer account via API.
Same API GET code easily accesses from Postman but when I try from logic machine I am receiving a time error.
Normally this happens when logic machine has wrong time and date but it seems the NTP and all settings fine.
Could you please give some guidance?
Best
Turker
* table:
["t"]
* number: 1729423258660
["msg"]
* string: request time is invalid
["code"]
* number: 1013
["success"]
* bool: false
["tid"]
* string: 617cb0ab8ed511efb25f867693c53a33
Check that your LM has correct timezone set. Post your script code.
Threads: 1
Thanks for quick answer. Time Zone is Europe/Madrid. Here is the code
https = require('ssl.https')
json = require('json')
ltn12 = require('ltn12')
token = '***********************'
--tuya
tbl = {}
res, code = https.request({
url = 'https://openapi.tuyaeu.com/v1.0/devices/***8dc756f81122a3al***/status',
method = 'GET',
headers = {
['authorization'] = 'Bearer ' .. token,
sink = ltn12.sink.table(tbl),
log(os.date('%c'))
if res and code == 200 then
resp = table.concat(tbl)
resp = json.pdecode(resp)
log(resp)
log(res, code)
I don't see any timestamp being passed to the request in your code. Do you have documentation on how the API calls should be made?
Threads: 1
Hello
I think after your guidance I have progressed on the time. Now the issue is I need to sign the GET code with HMAC-SHA256
How can we add a "crypto" library so this code can work:
local sign = crypto.hmac("sha256", str, secret):upper()
Thank you
Threads: 1
25.10.2024, 13:41
(This post was last modified: 25.10.2024, 13:41 by Ozturker.)
Thank you.
it worked but I think the ciphertext is not correct --> Here is the response string: {"code":1004,"msg":"sign invalid","success":false,"t
local ciphertext = client_id .. access_token .. t .. nonce .. identifier .. stringToSign
What is the identifer for Wiser?
identifier: The custom signature content for app authorization. When the authorization type is Android, you need to concatenate SHA1 and Application ID to form an identifier without a separator. For other types, you can directly use the customized Bundle Identifier.
