Trend problem
Hello
I have problems with the trends of the logic machine I have defined 4 trends, in the window I scroll through them but it shows me only the data of the first, the others do not display the data even if the description changes.
I have already tried or redefine the trend records but the problem still exists, what can I check?
Thanks so much
Do you record and data? Click on the Data button, bottom left in Trend view.
(16.03.2021, 15:05)Daniel. Wrote: Do you record and data? Click on the Data button, bottom left in Trend view.
Same thing does not change data series
Send me your backup to PM and I will have a look.
(16.03.2021, 15:09)Daniel. Wrote: Send me your backup to PM and I will have a look.
I don't find how to attach files in PM
Use wetransfer.com or similar
What HW and which FW do you use?
(16.03.2021, 15:36)Daniel. Wrote: Use wetransfer.com or similar
Hi Daniel You have receive my backup for problem in trend?
Hi, Yes sorry forgot to answer.
When you sent me the backup I can see that only one trend has some data, the rest 3 are empty. I kept running your project in my LM and it does work for me from the day I uploaded it. Can you try deleting the trends and creating them again?
(06.04.2021, 12:15)Daniel. Wrote: Hi, Yes sorry forgot to answer.
Hello
I tried to cancel and leave only one trrend, for total consumption. now I see how it goes.
thanks for everything.
