Different visualization same user
is it possible in a Wiser for KNX to visualize two different pages one for smartphone visualization and the other for normal visualization?
For example:
I have two different pages, I want the same user to visualize the first in smartphone and the other one on a PC.
Thank you for your help.
In Vis. structure you can configure whether plan is visible in each visualization mode.
Smartphone visu is equivalent of a custom visu only build automatically. User permission is only for one as both are the same. In Vis structure you can specify if a page is visible or not in smartphone(touch in LM) or custom visu. This way you can make it work.
Thank you!
