Threads: 57
Hello.
Since the code below floods my KNX bus, i want to have a delay between each loop. The os.sleep in the code below does not work. Can anyone explaine how i can delay this loop?
while Variable1 == true
do
Variable2 :write(true)
os.sleep (10)
Kai-Roger
Threads: 0
Use sleep(1) with no space between sleep and ().
Sent from my IN2023 using Tapatalk
Threads: 0
What's triggering the script?
All event scripts can run in parallel as many times as they are triggered.
Also it's not os.sleep() just sleep()
You probably have several instances of the same event script running. Please post the whole script code.
Threads: 57
Is there a difference between os.sleep and sleep? I see os.sleep is used by Erwin in the forum.
Kai-Roger
Threads: 0
I doubt it, probably just aliases.
Tested them now, they seem to work the same way.
