LogicMachine 5
LogicMachine5 is available for orders.
Main difference with former LM versions:
  • 3x more powerful than all previous LMs due to more powerful CPU and RAM
  • Additional power output with current and voltage monitoring – e.g. by interconnecting with KNX Choke you can see KNX bus voltage and current consumption
  • Automatic Ethernet connection checking and informing in case of troubles
  • Power-over-Ethernet powering
  • New enclosure for better heat dissipation
Here is more information: http://openrb.com/logicmachine5
LM comparison table (LM5 Reactors to come in some while): http://openrb.com/wp-content/uploads/201..._table.pdf
[Image: lm5-1d-300x350.png]
Nice jobWink I see you added not only 1 version of LM5 but a few. I also see the information "Microsoft Azure Certified". What this mean? Can I connect LM with Azure by selecting it from a list of supported devices or something else?
thx Smile
In the upcoming time we will prepare some example on how to send data from LogicMachine to cloud services.
Will this be the one with a faster processor than the LM4?
the current model has the same CPU, but there will be a version with faster CPU as well (we are finalizing tests for this new CPU module).
ok thanks
FYI, starting from today LM5 is supplied with 3x more powerful CPU than all previous LogicMachines.
