LM access but not giving Commands to KNX
Hi I have instellad an LM5p2-DR in a new project for the first time and I can access the device with IP I can ping it but when I am pressing for turning ON a light then it doesn't work
Why? I have connected the KNX (which I mesaured correct ) but I can't access the KNX somehow.
Is it possible to help me please?
Did you select correct KNX Mode? System-Network-KNX connection. It should be TP-uart.
(06.04.2021, 08:19)Daniel. Wrote: Did you select correct KNX Mode? System-Network-KNX connection. It should be TP-uart.
Oh yes I had it as IP Tunneling! Thank you very much!
