Add simple Textbox for send value.
I want to add simple Textbox (inputbox) Like as Html Textbox component..
Is it posible do it with visulation or should i use Scripting ?
Why don't you just use Text Label?
(07.04.2021, 11:23)Daniel. Wrote: Why don't you just use Text Label?
i want use text box like this for  sent to a value  maybe integer for dim value  or Send a start time like as "08:50" or send Some Text .. and  i need textbox style like this
Why Not use text Label Because There isnt main object for write KNX address in Text Label  properties
Well if you want to display text from an object then just use Display mode: value.
