Deconz REST API
Hi.
I have successfully managed to controll Ikea blinds with REST API sent to Deconz.
I have tested this in the "Postman REST client" i google Chrome, and i sent the following:
192.168.1.80:40850/api/8EBFA5778F/lights/2/state/
PUT
{ "lift": 50 }
When "putting" these lines the blinds roll down to 50%
How do i implement these 3 lines in a script in LM?
Kai-Roger
Try this:
http = require('socket.http')
ltn12 = require('ltn12')
body = '{"lift":50}'
res, code = http.request({
  url = '192.168.1.80:40850/api/8EBFA5778F/lights/2/state/',
  method = 'PUT',
  headers = {
    ['Content-Length'] = #body,
  source = ltn12.source.string(body)
log(res, code)
(19.04.2021, 06:31)admin Wrote: Try this:
  method = 'PUT',
  headers = {
log(res, code)
Excellent Smile Thanks. I had to put in http:// in front of the url, but else it worked perfectly.
Kai-Roger
Hi again.
I tried to use a variable (Percent) inside the Json expression in the "body". This does not work. Any tips on how to do this?
Percent    = event.getvalue    ()
--body = '{"lift":100}'
body = '{"lift":Percent}'
  url = 'http://192.168.1.80:40850/api/8EBFA5778F/lights/2/state/',
  method = 'PUT',
  headers = {
log(res, code)
Kai-Roger
Use this:
body = require('json').encode({
  lift = event.getvalue()
(20.04.2021, 06:24)admin Wrote: Use this:
Excellent Smile
Kai-Roger
