Threads: 24
Tesla recently changed its api to use v3 of the Tesla auth endpoint.
I've seen the V1 example script for logic machine, however the auth process seems a bit more complicated now!
An explanation of the auth process can be found here: https://tesla-api.timdorr.com/api-basics/authentication and here https://teslamotorsclub.com/tmc/threads/...st-5308136
I've seen an example script written in Python
https://github.com/fkhera/powerwallCloud...up.py#L132
Is anyone able to help me convert to lua to run on logic machine.
Specifically I'd like to automate a change in mode from 'backup-only' (which forces the Powerwall to charge from the Grid when rates are cheap) to 'self-powered' (which discharges the battery to power our home).
Many thanks in advanced
Kind Regards
James
Threads: 101
If you can provide username/password via PM then I can create an example.
Threads: 24
This should get you a request token and refresh token which can be used for further API calls. But this can stop working anytime if the login page structure changes since this example emulates user interaction with the login page.
Code: username = 'user@domain.com'
password = 'password'
client_id = 'ID'
client_secret = 'SECRET'
encdec = require('encdec')
http = require('socket.http')
mime = require('mime')
ltn12 = require('ltn12')
json = require('json')
function mt()
local ts, tu = os.microtime()
return ts .. '.' .. tu
function b64url(str)
return mime.b64(str):gsub('.', {
['/'] = '_',
function encodeargs(t)
local res = {}
local esc = require('socket.url').escape
for k, v in pairs(t) do
res[ #res + 1 ] = esc(k) .. '=' .. esc(v)
return table.concat(res, '&')
code_verifier = encdec.sha512(mt()):sub(1, 86)
state = b64url(encdec.sha256(mt()):sub(1, 12))
code_challenge = b64url(code_verifier)
args = encodeargs({
client_id = 'ownerapi',
code_challenge = code_challenge,
code_challenge_method = 'S256',
redirect_uri = 'https://auth.tesla.com/void/callback',
response_type = 'code',
scope = 'openid email offline_access',
state = state,
url = 'https://auth.tesla.com/oauth2/v3/authorize?' .. args
res, code, headers = http.request(url)
if not res or code ~= 200 then
log('request 1 failed', res, code)
return
postdata = {}
regexp = '<input type="hidden" name="([^"]+)" value="([^"]*)"'
for name, value in res:gmatch(regexp) do
postdata[ name ] = value
postdata.identity = username
postdata.credential = password
cookie = headers['Set-Cookie'] or headers['set-cookie'] or ''
body = encodeargs(postdata)
res, code, headers = http.request({
url = url,
method = 'POST',
source = ltn12.source.string(body),
headers = {
['Content-Type'] = 'application/x-www-form-urlencoded',
['Content-Length'] = #body,
['Cookie'] = cookie,
if not res or code ~= 302 then
log('request 2 failed', res, code)
return
hdr = headers.Location or headers.location
resp_code = hdr:match('code=([^&]+)')
body = json.encode({
grant_type = 'authorization_code',
code = resp_code,
code_verifier = code_verifier,
resp = {}
url = 'https://auth.tesla.com/oauth2/v3/token',
method = 'POST',
sink = ltn12.sink.table(resp),
headers = {
['Content-Type'] = 'application/json',
['Accept'] = 'application/json',
['User-Agent'] = 'Mozilla/5.0 (Linux; Android 9.0.0; VS985 4G Build/LRX21Y; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/58.0.3029.83 Mobile Safari/537.36',
['X-Tesla-User-Agent'] = 'TeslaApp/3.4.4-350/fad4a582e/android/9.0.0',
log('request 3 failed', res, code)
return
resp = table.concat(resp)
resp = json.pdecode(resp)
bearer_token = resp.access_token
refresh_token = resp.refresh_token
grant_type = 'urn:ietf:params:oauth:grant-type:jwt-bearer',
client_id = client_id,
client_secret = client_secret,
resp = {}
url = 'https://owner-api.teslamotors.com/oauth/token',
method = 'POST',
headers = {
['Authorization'] = 'Bearer ' .. bearer_token,
print(res, code)
log('request 4 failed', res, code)
return
access_token = resp.access_token
log(access_token)
Threads: 24
Many thanks for the example. I've loaded it onto my Schneider SHAC (which runs an older version of the logic machine os) however I get the following error
script:36: attempt to call field 'sha512' (a nil value)
Kind Regards
James
Try replacing these lines:
Code: code_verifier = encdec.sha512(mt()):sub(1, 86)
With this:
Code: rnd = encdec.sha256(mt())
code_verifier = (rnd .. rnd):sub(1, 86)
state = b64url(rnd:sub(1, 12))
Threads: 24
Hi .. The script progresses a little further with this change, however still errors
Can you suggest what else I should update?
* arg: 1
* string: request 1 failed
* arg: 2
* nil
* arg: 3
* string: error:1409442E:lib(20):func(148):reason(1070)
Kind Regards
James
This is due to outdated libraries in your firmware. Unfortunately it's not possible to update these libraries separately.
See if this works for you:
client_id = 'ID'
function mt()
['/'] = '_',
local res = {}
args = encodeargs({
state = state,
resp = {}
url = url,
protocol = 'tlsv12',
return
postdata = {}
for name, value in resp:gmatch(regexp) do
url = url,
method = 'POST',
headers = {
return
code = resp_code,
resp = {}
method = 'POST',
headers = {
return
resp = {}
method = 'POST',
headers = {
print(res, code)
return
log(access_token)
Threads: 24
Generating the new auth_token is working on my SHAC (with the old libraries)
Thank you!!!
I'd like to use this token to automate a change in mode from 'backup-only' (which forces the Powerwall to charge from the Grid when electricity rates are cheap) to 'self-powered' (which discharges the battery to power our home).
Could you please also help me convert the python code to pass this token back to the Tesla Powerwall to change the mode to Backup
Code: ## Set Powerwall Operation to Charge (Backup) or Discharge (self_consumption)
# Pause PERHAPS WITH (self_consumption) w/ Current SoC as backup_reserve_percent
def operation_set(self, real_mode, backup_reserve_percent):
# auth_header = {'Authorization': 'Bearer ' + self.token}
payload = {"backup_reserve_percent": backup_reserve_percent}
#payload = json.dumps({"real_mode": real_mode, "backup_reserve_percent": backup_reserve_percent})
set_endpoint = '/backup'
set_url = self.energy_base_url + str(self.energy_site_id) + set_endpoint
print ("Setting Operation for Site Id: ", self.energy_site_id)
print ("Trying URL: ", set_url)
print ("Setting mode: " + json.dumps(payload))
try:
result = requests.post(set_url, json=payload, headers=self.auth_header, timeout=50)
print("Set result output: ", result.content)
if result.status_code == 201:
print("Successfully changed reserve mode")
except HTTPError as err:
print("Error: {0}".format(err))
except Timeout as err:
print("Request timed out: {0}".format(err))#
Many thanks again
Kind Regards
James
This should provide a list of products which id should be used in the next request. Change gateway URL and token as needed.
Code: http = require('socket.http')
access_token = 'ABCDEF'
url = 'https://192.168.1.1/api/1/products'
resp = {}
url = url,
method = 'GET',
headers = {
['Authorization'] = 'Bearer ' .. access_token,
log(res, code, resp)
This request will set the battery reserve percent to 50. energy_site_id is the ID from the previous request.
energy_site_id = '123456'
backup_reserve_percent = 50
url = 'https://192.168.1.1/api/1/energy_sites/' .. energy_site_id .. '/backup'
backup_reserve_percent = backup_reserve_percent,
url = url,
method = 'POST',
headers = {
log(res, code, headers)
Threads: 24
I've implemented the above and can report back that it's working!
The IP address in the URL above should be replaced with 'https://owner-api.teslamotors.com'
I'm still having a little trouble capturing the energy_site_id .. how does one traverse the returned table with a numeric (1) table name.
https://owner-api.teslamotors.com/api/1/products returns data in the form
Code: * table:
[response]
* table:
[1]
* table:
[site_name]
* string: Home Energy Gateway
[energy_site_id]
* string: xxxxxxx
[id]
* string: xxxx-xxx-xxxx-xxxx
which I'd normally process as follows
Code: mydata = json.pdecode(table.concat(resp))
assetSiteD = mydata.response.1.energy_site_id
however the table name '1' in the above errors when I try to save the script
Code: Lua syntax error at line 200: malformed number near '.1.energy_site_id'
How do I reference the value with a table name of 1?
Kind Regards
James
Try this, or put quotes around 1 if it does not work.
Code: assetSiteD = mydata.response[1].energy_site_id
Threads: 24
The [1] works ... the quotes did not.
Many thanks
Threads: 101
Threads: 0
hi there - I have a similar set up and need to use LUA - I am getting the following
trial access Tesla 2 05.12.2021 13:48:50
* arg: 1
* string: request 2 failed
* arg: 2
* string: <HTML><HEAD>
<TITLE>Access Denied</TITLE>
</HEAD><BODY>
<H1>Access Denied</H1>
You don't have permission to access "http://auth.tesla.com/oauth2/v3/authorize?" on this server.<P>
Reference #18.9444c717.1638672530.1633eb30
</BODY>
</HTML>
* arg: 3
* number: 403
any suggestions - with thanks
Threads: 3
(05.12.2021, 03:03)mikeatlorne Wrote: hi there - I have a similar set up and need to use LUA - I am getting the following
* arg: 1
* arg: 2
</HEAD><BODY>
</BODY>
</HTML>
* arg: 3
* number: 403
Hi, anyone having the same problem or doing progress with this topic? Mine stops during the same step as above.
Best regards
Eilert Bjerkan
HW: LM5-M4(i.MX6), FW: 20200703
The login part has been modified so the automated way no longer works. The only way is to manually get both tokens. See this for more info: https://teslascope.com/help/generating-tokens
But in this case another script is needed to handle token refresh because they have a limited lifetime. It can be automated but if the token cannot be refreshed then it has to be updated manually again.
Threads: 101
(14.01.2022, 09:29)admin Wrote: The login part has been modified so the automated way no longer works. The only way is to manually get both tokens. See this for more info: https://teslascope.com/help/generating-tokens
i installed the Auth for Tesla app and get:
- Refresh Token
- Access Token
In the old situation it generates an Api Token and thats is used in the header.
How to use above codes in my lua code to get it working again?
Code: -- Load modules
https = require('ssl.https')
-- set credentials
username = 'my@email.com'
password = 'myPassword'
client_id = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" -- default, do not change unless Tesla makes changes
client_secret = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" -- default, do not change unless Tesla makes changes
-- all Tesla devices
tesla = {} -- car, vehicle_id
tesla[1] = {'myCar1', 'myVehicleId'}
CarID = tesla[1][2] -- run the script once, and look in the logs you will find a string called id_s this number is your vehicle ID, this should be replaced with the 123 in this field, remember to add "", then run script again, and you will get it to work!
function GetToken()
function mt()
['/'] = '_',
local res = {}
args = encodeargs({
state = state,
--log('request 1 failed', res, code)
return
postdata = {}
url = url,
method = 'POST',
headers = {
--log('request 2 failed', res, code)
return
code = resp_code,
resp = {}
method = 'POST',
headers = {
--log('request 3 failed', res, code)
return
resp = {}
method = 'POST',
headers = {
--print(res, code)
--log('request 4 failed', res, code)
return
return resp.access_token
-- Request token
if not API_Token then
API_Token = GetToken()
function RequestFromTesla(request)
request_url = 'https://owner-api.teslamotors.com/api/1/' .. request
local response_body = {}
local request_body = ""
local body, code, hdrs, stat = ssl.https.request{
url = request_url;
method = "GET";
headers =
["Content-Type"] = "application/json";
["Authorization"] = "Bearer " .. API_Token;
source = ltn12.source.string(request_body);
sink = ltn12.sink.table(response_body);
if code == 200 then
ret = table.concat(response_body)
ret = json.pdecode(ret)
return ret
API_Token = GetToken() -- request a new token
function WriteToTesla(request, request_body)
local content_length
if type(request_body) == "string" then
content_length = #request_body
request_body = ""
url = request_url;
method = "POST";
headers =
["Content-Length"] = content_length;
if code == 200 then
return ret
-- Get products
function get_products()
products = RequestFromTesla('products')
return(products) -- Check here your product ID
-- Get vehicles
function get_vehicles()
vehicles = RequestFromTesla('vehicles')
return(vehicles) -- Check here your Vehicles
-- Get onboarding data
function get_onboarding_data()
onboarding_data = RequestFromTesla('users/onboarding_data')
return(onboarding_data)
-- Get vehicle data
function get_vehicle_data()
vehicle_data = RequestFromTesla('vehicles/' .. CarID .. '/vehicle_data')
return(vehicle_data)
-- Wake up car
function wake_up()
result = WriteToTesla('vehicles/' .. CarID .. '/wake_up')
debugLog(result)
-- Unlock car
function door_unlock()
result = WriteToTesla('vehicles/' .. CarID .. '/command/door_unlock')
return(result)
-- Lock car
function door_lock()
result = WriteToTesla('vehicles/' .. CarID .. '/command/door_lock')
return(result)
-- Honk horn
function honk_horn()
result = WriteToTesla('vehicles/' .. CarID .. '/command/honk_horn')
return(result)
-- Flash lights
function flash_lights()
result = WriteToTesla('vehicles/' .. CarID .. '/command/flash_lights')
return(result)
-- Autocondition start
function auto_conditioning_start()
result = WriteToTesla('vehicles/' .. CarID .. '/command/auto_conditioning_start')
return(result)
-- Autocondition stop
function auto_conditioning_stop()
result = WriteToTesla('vehicles/' .. CarID .. '/command/auto_conditioning_stop')
return(result)
-- Set temperature
function set_temps(iDriverTemp,iPassengerTemp)
result = WriteToTesla('vehicles/' .. CarID .. '/command/set_temps?driver_temp='..iDriverTemp..'&passenger_temp='..iPassengerTemp)
return(result)
-- Charge port door open
function charge_port_door_open()
result = WriteToTesla('vehicles/' .. CarID .. '/command/charge_port_door_open')
return(result)
-- Start charging
function charge_start()
result = WriteToTesla('vehicles/' .. CarID .. '/command/charge_start')
return(result)
-- Stop charging
function charge_stop()
result = WriteToTesla('vehicles/' .. CarID .. '/command/charge_stop')
return(result)
-- Open trunk rear
function actuate_trunk()
result = WriteToTesla('vehicles/' .. CarID .. '/command/actuate_trunk', '{"which_trunk":"rear"}')
return(result)
-- Open trunk front
function actuate_frunk()
result = WriteToTesla('vehicles/' .. CarID .. '/command/actuate_trunk', '{"which_trunk":"front"}')
return(result)
Specify API_Token = 'xyz' together with other credentials then you should be able to use the RequestFromTesla/WriteToTesla functions. Keep in mind that the token has expiration time and has to be refreshed.
