LM SSL Certificate / Domain app
Hi All
We created app which will automatically generate SSL Certificate for selected domain.  The domain will be linked to local LM IP and thanks to this locally you will be able to use HTTPS communication with valid certificate. This will work only locally. LM must have internet connection for this to work.
Here is video how this works:
Will this app overwrites SSL certificate which is in System?
Done is better than perfect
Yes
How can I connect with SSL certificat in Zerotier VPN? I can´t access to Logic Machine local IP with zerotier, only with Logic Machine Zerotier VPN IP (172.24...)
ZeroTier is already encrypted so there's no point in using SSL there.
