User and password on ip cam
hello everyone,
I'm trying to view Hikvision IP cams with Mosaic (beta). But I can't pass username and password. Anyone have a solution?
The formula http://user: password@ip/aspi/....  is rejected by browsers.
thanks in advance to who want help me.
BR Cristian
Browsers do not allow URLs in user:pass@host format anymore for security reasons. Some cameras support passing user/pass as a URL query string parameters. If it still does not work then the only option is to disable authentication completely.
See this for possible URL formats: https://forum.logicmachine.net/showthread.php?tid=1073 https://www.ispyconnect.com/camera/hikvision
(03.05.2021, 06:53)admin Wrote: Browsers do not allow URLs in user:pass@host format anymore for security reasons. Some cameras support passing user/pass as a URL query string parameters. If it still does not work then the only option is to disable authentication completely.
Thanks I will see
Hi, I had a similar problem with a Hikvision camera.
I was unable to have it show in a stable way, not in mosaic, not in homeassistant, etc...). Spend quite some time on it.
Didn't have that problem with Axis camera, so I assume it's a Hikvision thing.
I solved it by using ispy v7.2 which I had already running on my server.
ispy can also produce streaming url's.
Camera 1 url is for example: http://10.0.0.15:8081/mjpegfeed?oid=1&size=300x410
Camera 2 url is for example: http://10.0.0.15:8081/mjpegfeed?oid=2
This works perfect, seamless and without headaches.
Downside you have to run a server 24/7, but if you already have one running this is the easiest way.
Note: ispy is replaced by ispy agent, don't know if it's still possible with that but you can still download ispy
