HifiBerry API GET
Hi.
Now that i have somewhat control over how to POST to the API, i'm having problems understanding how to use GET from the API. I have made a Resident script with 2 sec. sleep interval. The goal is to retrive volume % status on my HifiBerry amplifier, and write it to a group adress.
http = require('socket.http')
ltn12 = require('ltn12')
Volume_status                = grp.find        ('25/2/12')
--body = require('json').encode({
--  percent = tostring(event.getvalue())
res, code = http.request({
  url = 'http://192.168.1.91:81/api/volume',
    method = 'GET',
headers = {
    ['Content-Length'] = #body,
    ['Content-Type'] = 'application/json',
  source = ltn12.source.string(body)
Volume_status            :write(GET_Volume)
log(res, code)
The code above is a mess. Any ideas how to do this?
Kai-Roger
See if you can get a response using simple request command:
res, code = require('socket.http').request('http://192.168.1.91:81/api/volume')
log(res, code)
Otherwise you need a sink variable to store the response. Similar example: https://forum.logicmachine.net/showthrea...1#pid21631
(10.05.2021, 12:01)admin Wrote: See if you can get a response using simple request command:
log(res, code)
Yes i get a response. How do i retract the percent from this and write it to a group adress?
* arg: 1
  * string: {"percent": 47.0}
* arg: 2
  * number: 200
Kai-Roger
if res then
  res = require('json').pdecode(res)
  if type(res) == 'table' and res.volume then
    grp.checkupdate('1/2/3', res.volume)
(10.05.2021, 12:30)admin Wrote:
if res then
Thanks a lot. The code below works perfectly.
--log(res, code)
if res then
  if type(res) == 'table' and res.percent then
    grp.checkupdate('25/2/12', res.percent)
Kai-Roger
