lm ambient buzzer
I like to use the buzzer as posted in: Some LM Ambient questions (logicmachine.net)
But it doesn't work for me. Is there something changed?
And i also like to set the volume in a script.
Which LM Ambient do you have and which fw? I just tried RC1 and it works.
(20.05.2021, 08:14)Daniel. Wrote: Which LM Ambient do you have and which fw? I just tried RC1 and it works.
LMWECO2-ZR
With latest rc1 firmware: LM Ambient V2: https://dl.openrb.com/lm-21-imx6/lmwallv2-20210510.img
And is it correct that this device doesn't display a pm25 value?
Buzzer control for new HW (with volume control):
123456789101112131415
function beep(note, time, volume)   volume = volume or 10   volume = 1 + (11 - volume) ^ 2   local period = math.floor(10 ^ 9 / note)   local cycle = math.floor(period / volume)   local path = '/sys/class/pwm/pwmchip3/pwm0/'   io.writefile(path .. 'period', period)   io.writefile(path .. 'duty_cycle', cycle)   io.writefile(path .. 'enable', 1)   os.sleep(time or 0.1)   io.writefile(path .. 'enable', 0) end
(20.05.2021, 08:51)admin Wrote: Buzzer control for new HW (with volume control):
Thanks it works, and how lower the volume value, how harder the buzzer?
I suspect that the original firmware on your device was wrong and that your device does not have a PM2.5 sensor.
