Scheduler Status
I am implementing a UI for airco systems and use scheduler with events as a widget to schedule on/off times for the individual units. So far so good.
In the UI I would like to show additionally the status of each scheduler or for specific events in the scheduler, for the simple reason to quickly see if a schedule/event is active or not.
How do I retrieve the status of a schedule and its events to enable writing it to an object?
Only via DB queries, change IDs to your scheduler/events IDs:
-- scheduler
id = 1
active = db:getone('SELECT active FROM schedulers WHERE id=?', id)
active = toboolean(active)
grp.checkupdate('1/1/1', active)
-- event
id = 2
active = db:getone('SELECT active FROM scheduler_events WHERE id=?', id)
grp.checkupdate('1/1/2', active)
Thanks for the quick response, I got it working.
Hello, how can I simplify the script following this criterion?
-- scheduler1
id = 1
grp.checkupdate('40/0/' .. id, active)
-- scheduler2
id = 2
-- scheduler3
id = 3
-- scheduler4
id = 4
-- scheduler5
id = 5
Use a numeric for loop:
for id = 1, 5 do
  grp.checkupdate('40/0/' .. id, toboolean(active))
