filter table data NON DB
It is possible to filter id atts in a non-DB table
if I have a table from which I take data with
PowTable = storage.get ('MyPowerLog', {})
can I make a select on the data?
Thanks so much
You need to filter the table manually in a "for" loop. In this example the result table is populated will all items where the time field is not older than 1 day (86400 seconds).
12345678910111213
items = storage.get('MyPowerLog', {}) result = {} now = os.time() mintime = now - 86400 for _, item in ipairs(items) do   if item.time >= mintime then     table.insert(result, item)   end end log(result)
