Tulikivi sauna heater relay board
Hello
Could somebody help me with Tulikivi relay board for the sauna heater, trying to read sauna temperature with CMD 11, but the result always 0. When I connecting my touch panel, then pannel starts asking for data from the relay board and a log is showing some values. So the connection is established, but the request is wrong.
require('serial')
port, err = serial.open('/dev/RS485', {
  baudrate = 9600,
  databits = 8,
  stopbits = 1,
  parity = 'none',
  duplex = 'half'
port:flush()
port:write(0xB)
data = port:read(2,3)
byte = string.byte(data)
log(string.format("%o, %x, %d", byte,byte,byte))
port:close()
protocol attached
Thank you
.pdf   softa mat.pdf (Size: 91.39 KB / Downloads: 10)
Try this:
require('serial')
  baudrate = 9600,
  databits = 8,
  stopbits = 1,
  parity = 'none',
  duplex = 'half'
function send(cmd, data)
  local msg, res, err, b1, b2
  data = data or 0
  msg = string.char(
    bit.band(cmd, 0xFF),
    bit.band(bit.rshift(data, 8), 0xFF),
    bit.band(data, 0xFF)
  port:flush()
  port:write(msg)
  res, err = port:read(2, 3)
  if type(res) == 'string' then
    if #res == 2 then
      b1, b2 = res:byte(1, 2)
      return bit.bor(bit.lshift(b1, 8), b2)
      return nil, 'invalid reply'
    return nil, err
-- turn on
res, err = send(1, 1)
log(res, err)
-- turn off
res, err = send(1, 0)
log(res, err)
-- read current temperature
res, err = send(15)
log(res, err)
