Help with BluOS API
I need some help to control Monitor Audios IMS-4 from LM4 with help of this api.
BluOS API
I want to control:
ex:
Zone 1:
0/5/0 Play / Pause
0/5/1 Status Play / Pause
0/5/2 Stop
0/5/3 Status Stop
0/5/4 Back / Next
0/5/5 Shuffle
0/5/6 Status Shuffle
0/5/7 Repeat
0/5/8 Status Repeat
0/5/9 Volume 0-100%
0/5/10 Status Volume 0-100%
0/5/11 Mute
0/5/12 Status Mute
0/5/13 Playlist 0-255
0/5/14Preset 0-255
Zone 2:
0/5/0 Play / Pause
0/5/2 Stop
0/5/3 Status Stop
0/5/4 Back / Next
0/5/5 Shuffle
0/5/7 Repeat
0/5/8 Status Repeat
0/5/9 Volume 0-100%
0/5/11 Mute
0/5/12 Status Mute
0/5/14Preset 0-255
.pdf   BluOS Custom-Integration-API-v1.0.pdf (Size: 3.54 MB / Downloads: 18)
Here's a sample event script for volume control (0..100%). Change IP as needed:
volume = event.getvalue() ip = '192.168.1.100' url = 'http://' .. ip .. ':11000/Volume?level=' .. volume .. '&tell_slaves=1' res, err = require('socket.http').request(url) log(res, err)
You can implement other controls the same way just check the documentation on which URL path and parameters must be used. If you have a player with several nodes in one then use port 11010 for zone 2 instead of 11000. Status retrieval can be done via a resident script but it's more complicated. See if control works for you first.
