Scrit HTTP request timeout
Got a LM5 i.MX6 with most recent fw (20210510) and I?m experiencing a wired issue
IP configuration is correct.. I can ping 8.8.8.8 and traceroute www.google.com correctly, but.. all lua script that uses socket.http library goes in timeout error.
luasocket library is version 2.0.2-20210217
This of course will prevent any script to run as they are intended.
Is is an issue someone else has faced and fixed?
thanks
Regards
P.S.
this is the script:
require('json') local http = require('socket.http') http.TIMEOUT = 30 local OWMLINK    = 'https://api.openweathermap.org/data/2.5/onecall?' local OWMAPIKEY  = '' local OWMUNIT    = 'metric' local OWMLAT     = local OWMLON     = local OWMLANG    = 'it' local OWMEXCLUDE = 'minutely,hourly' OWMLINK = OWMLINK..'lat='..OWMLAT..'&lon='..OWMLON..'&appid='..OWMAPIKEY..'&units='..OWMUNIT..'&exclude='..OWMEXCLUDE log(OWMLINK) local OWMResponse, code, headers, status= http.request(OWMLINK) log(code, status, headers) if not OWMResponse then   alert('Previsioni OpenWeather: Impossibile recuperare dati')   return end local data = json.pdecode(OWMResponse) if not data then   alert('Previsioni OpenWeather: Impossibile convertire dati')   return end
variable "code" result timeut
...it is not a timeout parameter issue Wink
this is an example.. I do have the telegram notification script that doesn't work either
Try Like this,
require('json') local http = require('socket.http') local OWMLINK    = 'https://api.openweathermap.org/data/2.5/onecall?' local OWMAPIKEY  = '' local OWMUNIT    = 'metric' local OWMLAT     = '41.8719' local OWMLON     = '12.5674' local OWMLANG    = 'it' local OWMEXCLUDE = 'minutely,hourly' local OWMResponse, err= http.request( OWMLINK..'lat='..OWMLAT..'&lon='..OWMLON..'&lang='..OWMLANG..'&exclude='..OWMEXCLUDE..'&appid='..OWMAPIKEY..'&units='..OWMUNIT) log(OWMResponse, err) if OWMResponse then     local data = json.pdecode(OWMResponse)    log(data)       else if err then   log('ERROR :' .. err)   end end
thnaks...
I found the issue.... I made a BAD mistake on the NAT setup on my router....
it is now working good
thanks
ciao
M
