Get a script's sleep interval programmatically
Is it possible to retrieve the value of the sleep interval of a resident script programmatically?
I can retrieve the scripts' object using "script.get('script name')" which includes the script id/type/status but it doesn't include the sleep interval configured for the script unfortunatley.
Thank you!
Morkov
Found out how to do it, for anyone else interested:
script_id = script.get(_SCRIPTNAME).id
script_timer = db:getrow('SELECT params FROM scripting where id = ?', script_id).params
Thank you!
Morkov
What is the use case for this?
I wanted to use it in the function that measures the wiser performance metrics (knx load, cpu, memory) - for the knx load it assumed a certain amount of time passed since last invocation (60 sec) to calculate the load.
Thank you!
Morkov
