MQTT Client example
recently I was trying to find some examples how LM supports MQTT protocol, as it is stated in marketing materials, but I was not able to find one. I imagine the concept of  MQTT support in this way.
Some mqtt client daemon has to run on LM.
LM as a publisher - it is possible to publish group address values to topics.
LM as a subscriber  it is possible to subscribe to topics and assign values to group address.
1. Is my understanding correct?
2. Could you point me out some tutorials?
Thank you for response in advance
Anton
bump up
MQTT packages:
https://dl.openrb.com/lm-17/pkg/libcares...-1_mxs.ipk
https://dl.openrb.com/lm-17/pkg/libmosquitto_1.4.11-1_mxs.ipk
https://dl.openrb.com/lm-17/pkg/luamosqu...-1_mxs.ipk
Lua library:
https://github.com/flukso/lua-mosquitto/
(08.08.2016, 06:11)admin Wrote: MQTT packages:
https://dl.openrb.com/lm-16.07-rc/pkg/li...-1_mxs.ipk
https://dl.openrb.com/lm-16.07-rc/pkg/lu...-1_mxs.ipk
Lua library:
All working. I use Resident script with 60 sec loop. All subscriptions received just in time.
Should I use resident script only?
And just in case: I use login_set before connect
client:login_set("login","pass")
Hey guys, I tried to download packages for mqtt client but I've got 404 error, any ideas where could I find them?
Thanks,
David
Same here. Need them for my Azure testing towards an IoTHub.
Please provide them again for download Smile
Best regards
Eilert
