Run a script from another script
In certain conditions I need to run a script from another script, I can trigger it by using:
script.disable('script2') script.enable('script2')
But is there a simpler way, such as a script.run('scriptname')?
Thank you!
Morkov
Use an event script with a virtual object or place a function into common functions and execute it directly.
(07.09.2021, 06:06)admin Wrote: Use an event script with a virtual object or place a function into common functions and execute it directly.
In this case I prefer to keep using the disable/enable as it's simpler - the script I want to execute needs to be a resident script, so adding a virtual object and an event script just for this seems excessive, as is placing a function into the common functions.
Thank you
Thank you!
Morkov
