Lost password on Logicmachine
Hi!
I have one Logicmachine, where the password is lost.
What is the best way to fix this?
If i take a reset, is it only IP adress that goes to default or is the user also reset to admin, admin?
The customer has some script on the device that i dont won't to loose. Confused
-s-
Do you use LM or SE w4k or SL?
just LM
PM
(15.09.2021, 12:36)Daniel Wrote: Do you use LM or SE w4k or SL?
Daniel,
Same problem (self inflicted I'm afraid). Also just LM and also don't want to loose the configuration
Would you be so kind to send me the reset procedure?
Kind regards,
Hendrik
