flashing alert
Smile Hello
Did anyone make a flashing alert by Scrip?
Someone can help or send a scrap, of course in no-alert mode, the flicker stops. Regards
Do you want to do this in standard visualization or Mosaic? What kind of alert do you want - an icon or text label? What type is the alert object - 1 bit or something else?
(28.09.2021, 05:45)admin Wrote: Do you want to do this in standard visualization or Mosaic? What kind of alert do you want - an icon or text label? What type is the alert object - 1 bit or something else?
Greetings Smile
Thanks for the reply I want an alert in the icon, in 1 bit, I did not understand what is visualization or Mosaic. I work in a visualization screen. Thanks
You can do it with a transparent picture if there is no problem
and a animated gif with to pictures in it, 1 transparent and one with symbol of problem you want.
something like this
[Image: Alert.gif]
sourch: https://commons.wikimedia.org/wiki/File:Alert.gif
Animated GIF is an easy solution.
This can also be achieved with Custom JavaScript. This example will show/hide all elements with additional class set to alert every second when 0/1/24 value is set to true. You can also change $('.alert').removeClass('hide'); to $('.alert').addClass('hide'); to hide the element when the object value is false.
$(function(){
  if (window.grp) {
    var timer;
    grp.listen('0/1/24', function(object) {
      if (object.value) {
        if (!timer) {
          timer = setInterval(function() {
            $('.alert').toggleClass('hide');
          }, 1000);
      else {
        clearInterval(timer);
        timer = null;
(29.09.2021, 06:12)admin Wrote: Animated GIF is an easy solution.
$(function(){
  if (window.grp) {
    var timer;
      if (object.value) {
        if (!timer) {
          }, 1000);
      else {
        timer = null;
great and easy, alternative to creating GIF.
But how to make it depend on the element value (Binary) instead of a specific object?
You can find the mapped group address like this: https://forum.logicmachine.net/showthrea...5#pid20275
(29.09.2021, 08:16)admin Wrote: You can find the mapped group address like this: https://forum.logicmachine.net/showthrea...5#pid20275
Thank you admin for advising me to do it by myself.
This is what I did is there any advice?
// Flashing Alert
$(function(){
    $('.alert').each(function(_, el) {
    var timer;
    var addr = $(el).data('object');
    if (addr) {
  grp.listen(addr, function(obj) {
      if (obj.value) {
        if (!timer) {
          }, 500);
      else {
        timer = null;
// Flashing Alert
$(function(){
    var timer;
    if (addr) {
      if (obj.value) {
        if (!timer) {
          }, 500);
      else {
        timer = null;
Thanks for the answers I will try thanks Smile
If you reference $('.alert') further in the code this means that all elements with alert class will be flashed if at least one objects is set to true. So it won't work for multiple/different alert objects. Try this (not tested):
$(function() {
    var $el = $(el);
    var addr = $el.data('object');
    var timer;
    if (addr) {
        if (obj.value) {
          if (!timer) {
              $el.toggleClass('hide');
            }, 500);
        else {
          $el.removeClass('hide');
          timer = null;
(29.09.2021, 10:36)admin Wrote: If you reference $('.alert') further in the code this means that all elements with alert class will be flashed if at least one objects is set to true. So it won't work for multiple/different alert objects. Try this (not tested):
$(function() {
    var $el = $(el);
    var timer;
    if (addr) {
        if (obj.value) {
          if (!timer) {
            }, 500);
        else {
          timer = null;
That's right, I didn't notice that because I tested it on one object
your script seems to work fine, I tested it for two objects and work fine
$(function(){
  if (window.grp) {
    var timer;
      if (object.value) {
        if (!timer) {
          }, 1000);
      else {
        timer = null;
Hello
I entered the script but I have a lot of error messages you can check it again thanks
? p.s  my object 1/7/20  thanks
$(function(){
  if (window.grp) {
    var timer;
      if (object.value) {
        if (!timer) {
          }, 1000);
      else {
        timer = null;
Hello
I used the script and its works fine.
do you insert the script in the custom JavaScript page: Scripting> Tools> Edit custom JavaScript
$(function(){
  if (window.grp) {
    var timer;
      if (object.value) {
        if (!timer) {
          }, 1000);
      else {
        timer = null;
Hello
Thanks, I inserted the scrap as you just said. How now I enable it after inserting a JavaScript page: Scripting> Tools> Edit custom JavaScript?
[quote pid="23203" dateline="1632991948"]
[/quote]
Just save
To see the effect you should open the PC/Tablet Page if you are using SL or W4KNX.
you will not see the effect on the visualization editor page.
(30.09.2021, 09:00)khalil Wrote: [quote pid="23203" dateline="1632991948"]
Just save
[/quote]
Hi, I'm not a JAWA expert. Do I need to add value / object to what you sent? I tried through the screen non-flashing visual, I just need a sample object 1/7/10 (1 bit) in the sample problem so it flashes at about 0 it does not flash. Thanks Cool
Use this code
https://forum.logicmachine.net/showthrea...3#pid23183
and add additional calss 'alert' to your object in visu editor.
(28.09.2021, 17:13)Dré Wrote: You can do it with a transparent picture if there is no problem
something like this
[Image: Alert.gif]
hello
Thank you very much, is this an icon you created? Can I create or change captions myself? ERRO for example? Regards
Create two images and convert them to gif, there are loads of sw available for example this https://imgflip.com/gif-maker
something like this
[Image: Alert.gif]
I tried thanks I took the same symbol (Alert) but the flicker disappeared
