Modbus RTU - Relais-Board
Would there be practical experiences available in relates to connecting and successfully controlling an
Eletechsup DC 12V 8 Ch RS485 Relay Board (Modbus RTU) ?
Kind regards,
Boris
Do you have any documentation for it?
Hello Daniel
Thank you for your quick reply.
There are some rudimentary documentations available - although I was naively assuming, it would only require to set the ModBus-ID and ComPortSpeed in order to be discovered by the LM5. Have I been mistaken?
Kind regards, Boris
.pdf   8 Channel RS485 Relay Manual.pdf (Size: 2.92 MB / Downloads: 102)
.pdf   8 channel rs485 commamd.pdf (Size: 233.49 KB / Downloads: 109)
Connect it up and try reading from it via RTU read test. Use holding register and try address 0 and 1
