Threads: 31
This is blocked for security. In LM we have Zerotier which lets you connect securely. Contact SE support directly.
Threads: 8
Check the official communication from KNX Assosiation later today.. Then you know why we closed it ..
Threads: 30
I understand the problem, and I'm aware of the KNX secure process etc etc, but I have an old installation without a VPN and I have to reach it, is there a way?
Threads: 31
If you use VPN then you don't need NAT. Only public IPs are blocked. When you are on VPN then you use local IPs,
Threads: 30
Yes, I know it, but I didn't have a VPN there, is it possible to reach the bus via ETS in that case?
Thank you
Threads: 31
Via LM yes, Wiser NO
Threads: 15
I have LM in local network behind the firewall and I made a custom port with restricted source IP that redirects to LM 3671.
However it does not work - my i3pro application does not work from outside the network even the fw shows all redirects are working properly.
What could cause a problem? is there any way to check LM logs for KNX connections?
thanks
Threads: 8
Did you enabled "NAT mode" in the ETS connection settings?
Threads: 42
Hello, in LM devices with old Firmware, would it be enough to uncheck the option of 'KNX IP Features'? so the access would be blocked by the 3671?
Yes, disabling IP features is enough
Threads: 31
Only if you use TP-UART mode, If Routing is selected then this is still enabled.
Dynamic DNS does not provide any kind of protection. It does not matter if it's a domain name or an IP address. Opening port 3671 is a security issue in a any case.
Threads: 3
There is no other way to connect to port 3671 other than via VPN, otherwise it is not possible?
I have a problem on my computer with an L2TP connection, it is disabled by WIN-10. I've already gone through what, no change in settings has helped, not even in the registers.
Threads: 31
Have you tried ZeroTier? It is not VPN strictly speaking.
Threads: 3
16.02.2022, 17:13
(This post was last modified: 16.02.2022, 17:43 by Dan22.)
I haven't tried zero tier, there is a guaranteed guide somewhere, I would not like to go to LM at the customer's
Daniel,
Thanks for the advice, ZT works.
