Log all packets from 15.15.*
Is there any easy way to log all packets coming from source 15.15.* ? (without making a tag on all objects)
I have some units that use 15.15.* when they are starting up and after a while change the address to the right configured address. And I want to log if these units have any other strange behavior.
Regards
Klaus
Hi Klaus,
you could use such script and customize handleLog function according to your needs.
if not client then   require('genohm-scada.eibdgm')   objects = grp.all()   datatypes = {}   for _, object in ipairs(objects) do     datatypes[ object.id ] = object.datatype   end     function handleLog(src, eventType, ga, value, rawEvent)     local isLoggedAddress = src:find("15.15.%d+") ~= nil     if isLoggedAddress then       log(src, eventType, ga, value, os.time())     end   end   function writehandler(event)     local dpt, dst = datatypes[ event.dstraw ], event.dst     local value = nil         if dpt then       value = knxdatatype.decode(event.datahex, dpt)     end         handleLog(event.src, event.type, dst, value, event)   end       client = eibdgm:new({ timeout = 0.5 })   client:sethandler('groupwrite', writehandler) end -- handle knx client:step()
You could look also into these posts:
https://forum.logicmachine.net/showthrea...ght=eibdgm
Done is better than perfect
It did the job - thanks
Smile
Awesome!
