Threads: 79
01.12.2021, 11:17
(This post was last modified: 01.12.2021, 11:18 by khalil.)
Hello
I have a SL installed stop responding
V1.4
LED1 Yellow Blinking
LED2 Yellow Steady
ethernet Green Blinking/ Orange Steady
what could I do
Best Regards,
Threads: 29
For v1.4 it is probably SD card. Replace and see agian.
Threads: 29
You should use new card, not the same one. You can try of making existing card image and restore it on new.
Threads: 29
In this case it means some files were already corrupted and it is hard to extract stuff from it. I would recommend restore any backup you have and start from there
Threads: 29
If you restore full card image then it is full copy of the device also systems. When you restore backup then the system is unchanged.
Threads: 10
Hello i have the same problem with a spacelynk v1.2
i already changed the card and i did a factory reset
i did also the FW update 2.8.0
at first it opens, but if the power cuts SL stop working, no ping ( led statuts are normal )
Threads: 29
Did you flash the card with recovery image or did you copy old SD to new?
Threads: 7
05.05.2023, 11:34
(This post was last modified: 05.05.2023, 11:48 by Erwin van der Zwart.)
Do you have HW3.2? If yes, did you use recovery-imx6-1g.img for the recovery?
If you have older HW, did you extract the image so it is around the 950Mb before restore it to the SD card with USB image tool?
Threads: 7
That could be the case, however defect HW is very rare, have seen 1 device that was realy broken (aka not SD card related) up to now in all those years...
