Threads: 24
Hi @all,
are there any plans to integrate EEBUS function for charging/wallbox use case?
Many thanks in advance.
Best Regards
Steffen
Threads: 31
EEBus is DE only. SE version will have this integrated. We see no market for this yet.
Threads: 24
31.05.2022, 12:54
(This post was last modified: 31.05.2022, 17:35 by pioneersteffen.)
Hi @all,
has anybody information if and when SE will release EEBUS for W4K? If SE is looking for a beta tester I would be happy to help - I having two EEBUS wallboxes with Kostall solar inverter and a battery.
Is there any scripting solution to control a wallbox via EEBUS as an alternative? I just want to read the plug and charging status and set the max. allowed current.
Many thanks for your help!
Best Regards
Steffen
Rewriting such code is very time-consuming. Go has an ability to be compiled into a static binary that can be run on the controller without installing any additional packages. You can get an RPi or use a virtual machine to play with this solution but it's not something that we can help with.
Threads: 24
Hi admin,
many thanks for your help! The idea to compile it to an static binary and let it run on LogicMachine sounds promising. Do you have a hint how to let a static binary start/run on LogicMachine?
Many thanks!
Best Regards
Steffen
