Threads: 32
Dear, as I am a novice in scripting. Anyone that can help me in reading out doorbell status to link to object in KNX?
Hik doorbell KV6113-WPE1 uses a curl command:
Code: curl -i --digest -u admin:xxx http://192.168.x.x/ISAPI/VideoIntercom/callStatus?format=json
Should give as output : “idle” , “ring” , “onCall”
during "ring" it must set a boolean to 1 All others 0.
Threads: 32
I found that one using the search function but this is about getting a snapshot not a datapoint. So i don't understand the link. Sorry i am really novice in scripting ;-)
Copy the script for the example and change two last lines and log the result. Change 123456789 to your device password and change the IP address as needed.
Code: url = 'http://admin:123456789@192.168.1.1/ISAPI/VideoIntercom/callStatus?format=json'
res, err, hdrs = request(url)
log(res, err, hdrs)
Threads: 32
01.01.2022, 20:30
(This post was last modified: 01.01.2022, 20:31 by KoBra.)
Thx for the help.
I made a script from some copy pasting of other scripts i have running. But i don't get the different value.
The reply from the bell in the JSON is the following:
Code: {
"CallStatus": {
"status": "idle"
But with the following script i get no value from the doorbell:
Code: require('json')
require('socket.http')
data = socket.http.request('http://admin:xxxx@192.168.0.0/ISAPI/VideoIntercom/callStatus?format=json')
data = json.pdecode(data)
if type(data) == 'table' then
data = data['CallStatus'][ 1 ]
log(data)
-- Status
grp.checkwrite('32/5/1', data.status)
alert('request failed')
Sorry i am just not good at scripting (yet)
Try this:
Code: if type(data) == 'table' then
status = data.CallStatus.status
grp.checkwrite('32/5/1', status)
Threads: 32
02.01.2022, 14:05
(This post was last modified: 02.01.2022, 14:34 by KoBra.)
Tried it both as Resident or as Event based script but both don't write a value at the 32/5/1 address... "Request Failed". No idea where it goes wrong.
I tested the login with credential in Chrome on a incognito window. There it accepts the HTTP including the login credentials.
It does not work because the standard HTTP library does not support digest authentication scheme. You need to use code from this example instead: https://forum.logicmachine.net/showthrea...64#pid9364
Threads: 32
(03.01.2022, 06:27)admin Wrote: It does not work because the standard HTTP library does not support digest authentication scheme. You need to use code from this example instead: https://forum.logicmachine.net/showthrea...64#pid9364
If i test with script below i get the same error...
Code: local skthttp = require('socket.http')
local skturl = require('socket.url')
local ltn12 = require('ltn12')
local md5sum = require('encdec').md5
local hash = function(...)
return md5sum(table.concat({...}, ':'))
local parse_header = function(header)
local result = {}
for key, value in (header .. ','):gmatch('(%w+)=(.-),') do
if value:sub(1, 1) == '"' then -- strip quotes
result[ key:lower() ] = value:sub(2, -2)
return result
local make_digest_header = function(headers)
local digest = {}
for _, header in ipairs(headers) do
if not header.unquote then
header[ 2 ] = '"' .. header[ 2 ] .. '"'
digest[ #digest + 1 ] = header[ 1 ] .. '=' .. header[ 2 ]
return 'Digest ' .. table.concat(digest, ', ')
local _request = function(req)
if not req.url then
return nil, 'missing url'
local url = skturl.parse(req.url)
local user, password = url.user, url.password
local sink = req.sink
if not user or not password then
return nil, 'missing credentials in url'
url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil
req.url = skturl.build(url)
local source
if req.source then
local chunks = {}
local capture = function(chunk)
if chunk then
chunks[ #chunks + 1 ] = chunk
return chunk
local chunk_id = 0
source = function()
chunk_id = chunk_id + 1
return chunks[ chunk_id ]
req.source = ltn12.source.chain(req.source, capture)
req.sink = nil
local body, code, hdrs = skthttp.request(req)
if code == 401 and hdrs['www-authenticate'] then
local ht = parse_header(hdrs['www-authenticate'])
if not ht.realm or not ht.nonce then
return nil, 'missing realm/nonce from response'
local qop = ht.qop
if qop and qop ~= 'auth' then
return nil, 'unsupported qop ' .. tostring(qop)
if ht.algorithm and ht.algorithm:lower() ~= 'md5' then
return nil, 'unsupported algo ' .. tostring(ht.algorithm)
local nc = '00000001'
local cnonce = string.format('%08x', os.time())
local uri = skturl.build({ path = url.path, query = url.query })
local method = req.method or 'GET'
local response = hash(
hash(user, ht.realm, password),
ht.nonce,
nc,
cnonce,
'auth',
hash(method, uri)
req.headers = req.headers or {}
local auth = {
{ 'username', user },
{ 'realm', ht.realm },
{ 'nonce', ht.nonce },
{ 'uri', uri },
{ 'cnonce', cnonce },
{ 'nc', nc, unquote = true },
{ 'qop', 'auth' },
{ 'algorithm', 'MD5' },
{ 'response', response },
if ht.opaque then
table.insert(auth, { 'opaque', ht.opaque })
req.headers.authorization = make_digest_header(auth)
if not req.headers.cookie and hdrs['set-cookie'] then
-- not really correct but enough for httpbin
local cookie = (hdrs['set-cookie'] .. ';'):match('(.-=.-)[;,]')
if cookie then
req.headers.cookie = '$Version: 0; ' .. cookie .. ';'
if req.source then
req.source = source
req.sink = sink
return body, code, hdrs
local request = function(url)
local t = type(url)
if t == 'table' then
return _request(table.clone(url))
elseif t == 'string' then
local req = {}
local _, code, headers = _request({ url = url, sink = ltn12.sink.table(req) })
return table.concat(req), code, headers
url = 'http://admin:XXXX@192.168.0.1/ISAPI/VideoIntercom/callStatus?format=json'
image, err, hdrs = request(url)
require('json')
grp.checkwrite('32/5/1', data.CallStatus.status)
alert('request failed doorbell')
Line 136 should be:
data, err, hdrs = request(url)
Otherwise result is assigned to the image variable not data
Threads: 32
 Hoe could I be that stupid… tnx it works!
Threads: 22
03.03.2022, 07:08
(This post was last modified: 03.03.2022, 07:09 by Krstfr2k.)
I am sorry to hijack the thread, but how would implement the following in the script example that is provided by Admin?
Code: curl --location --request PUT 'https://exampleadr.com/pms_api/:subscription_id/:account_id/rooms/:room_id' \
--data-raw '{
"room": {
"housekeeping_status": "inspect"
Use this, adjust URL (including id parameters) as needed:
Code: http = require('socket.http')
json = require('json')
url = 'https://exampleadr.com/pms_api/:subscription_id/:account_id/rooms/:room_id'
body = json.encode({
room = {
housekeeping_status = 'inspect'
res, code = http.request({
url = url,
method = 'PUT',
body = body
log(res, code)
Threads: 22
(03.03.2022, 08:33)admin Wrote: Use this, adjust URL (including id parameters) as needed:
room = {
url = url,
method = 'PUT',
body = body
log(res, code)
The API uses Digest Auth, would the example above work in that case or would the earlier example in this thread need to be adjusted?
In this case you need to pass request source differently and also put username and password into the URL. Also don't forget to include digest library code before this.
Code: json = require('json')
url = 'https://username:password@exampleadr.com/pms_api/:subscription_id/:account_id/rooms/:room_id'
room = {
resp = {}
res, code = request({
url = url,
method = 'PUT',
headers = {
['Content-Type'] = 'application/json',
['Content-Length'] = #body,
source = ltn12.source.string(body),
sink = ltn12.sink.table(resp),
print(res, code, resp)
Threads: 22
(03.03.2022, 09:04)admin Wrote: In this case you need to pass request source differently and also put username and password into the URL. Also don't forget to include digest library code before this.
room = {
resp = {}
url = url,
method = 'PUT',
headers = {
Thank you so much for the help, worked perfectly!
Threads: 8
How i can send a command for open a door / Relay:
curl -i --digest -u admin:xxx -X PUT -d '<RemoteControlDoor><cmd>open</cmd></RemoteControlDoor>' http://192.168.0.xx/ISAPI/AccessControl/...rol/door/1
thank you
You need to use digest auth request function from this example: https://forum.logicmachine.net/showthrea...64#pid9364
Code: body = '<RemoteControlDoor><cmd>open</cmd></RemoteControlDoor>'
url = 'http://admin:123@IP/...',
method = 'PUT',
headers = {
log(res, code)
