Equal script to FBeditor input selection switch
Hello
Is someone having a more simple event based script that is equal to FBeditor Input selection switch?
require('custom.fbeditor20.Select_switch') functions_Select_switch_json_fbe_input_selection_switch_input_1 = grp.getvalue('2/4/0') functions_Select_switch_json_fbe_input_selection_switch_input_2 = grp.getvalue('32/1/7') functions_Select_switch_json_fbe_input_selection_switch_input_3 = grp.getvalue('32/1/6') out = fbe_input_selection_switch(functions_Select_switch_json_fbe_input_selection_switch_input_1, functions_Select_switch_json_fbe_input_selection_switch_input_2, functions_Select_switch_json_fbe_input_selection_switch_input_3, 'fb__Setpunktvalg_A101__fbe_input_selection_switch__id') if out ~= nil then     grp.write('2/0/51', out) end
Something like this should do.
TAG all input objects and select and create event script from this TAG
select = grp.getvalue('1/1/1') input1 = grp.getvalue('1/1/2') input2 = grp.getvalue('1/1/3') input3 = grp.getvalue('1/1/4') outgrp = '1/1/5' if select == 1 then grp.checkwrite(outgrp, input1) elseif select == 2 then   grp.checkwrite(outgrp, input2) elseif select == 3 then   grp.checkwrite(outgrp, input3)  end
Thank you, it works very well.
Is it possible to add an delay in the script, so it waits few seconds before it runs when the select switch change state?
Adding delay in event script which is triggered by few objects is not recommended as it will run each time when change happen and each time delay will start. You may end up in situation when not correct input is selected in time.
Delay is simply added like this
-- wait for 1.5 seconds
os.sleep(1.5)
