Converting Python to Lua
I found this python script that I´m anxious to get working with Lua. Not to familiar with http socket scripting though.
Is it possible to get this to work?
Its for a Wifi coffee maker. Finally I can make coffee at the touch of a button  Big Grin
#!/usr/bin/env python import sys import socket import json #method names to validate API_METHOD_BREW = "brew" API_METHOD_RESET = "reset" #IP address of the smarter coffee machine on your network TCP_IP = 'XXX.XXX.XXX.XXX' TCP_PORT = 2081 BUFFER_SIZE = 10 #default method to call api_method = sys.argv[1] if api_method == API_METHOD_BREW:     message_to_send = "7" elif api_method == API_METHOD_RESET:     message_to_send = "\x10" #make connection to machine and send message try:     s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)     s.connect((TCP_IP, TCP_PORT))     s.send(message_to_send)     data = s.recv(BUFFER_SIZE)     s.close() except socket.error, msg:     print 'Failed to create socket. Error code: ' + str(msg[0]) + ' , Error message : ' + msg[1]     sys.exit(); #convert response from machine to unicode return_code = unicode(data) #set default values to ouput success=0 message="" #find out what the machine response means if return_code =="\x03\x00~":     success=1     message="brewing" elif return_code=="\x03\x01~":     message="already brewing" elif return_code=="\x03\x05~":     message="no carafe" elif return_code=="\x03\x06~":     message="no water" elif return_code=="\x03i~":     success=1     message="reset" else:     message="check machine" #ouput JSON to whatever called this script print json.dumps({'success': success,'message':message,'return_code':repr(data)[1:10]}) quit() sys.exit()
