Javascript to check lost communications
Is there a way to check in the Custom Javascript if there is communicaiton with the LM?
Smetimes the clients loose comms and the touch screen seems to work, but all actions are not sent to the LM.
Thanks in advance,
Leonardo
There are two events that you can use:
$(localbus).on('connect', function() {   console.log('connected');   }); $(localbus).on('disconnect', function() {   console.log('disconnected');   });
