curl to lua
I am trying to convert a curl command to lua but cannot get it to work...
This is the curl command:
curl -X POST \
-H 'Content-Type: application/json' \
-d '{"jsonrpc":"2.0", "id":1", "method": "Input.Down"}' \
http://user:passwd@192.168.0.24:8080/jsonrpc
Result:
{"id":"1", "jsonrpc":"2.0", "result":"OK"}
This is the lua code:
socket = require('socket.http')
socket.TIMEOUT = 5
url = 'http://user:passwd@192.168.0.24:8080/jsonrpc'
body = '{"jsonrpc": "2.0", "id": 1, "method": "Input.Down"}'
res, code = socket.request({
    url = url,
    method = 'POST',
    body = body,
    headers = {'Content-Type: application/json'
log(res)
log(code)
This results in:
testing 22.01.2022 16:14:46
* number: 200
* number: 1
Any hints?
TIA.
Try this:
require("ltn12")
res = {}
body = '{"jsonrpc":"2.0","id":1,"method":"Input.Down"}'
socket.http.request({
  url = "http://user:passwd@192.168.0.24:8080/jsonrpc",
  method = 'POST',
  sink = ltn12.sink.table(res),
  headers = {
    ['content-length'] = #body,
  source = ltn12.source.string(body),
log(res)
(22.01.2022, 22:58)Erwin van der Zwart Wrote: Try this:
require("ltn12")
res = {}
  method = 'POST',
  headers = {
log(res)
This works!
Bedankt Erwin!
Specifying sink is not needed in newer firmwares. The library will create a sink automatically and will return the request result as a string.
(24.01.2022, 07:08)admin Wrote: Specifying sink is not needed in newer firmwares. The library will create a sink automatically and will return the request result as a string.
I am on 20160714 firmware...
