Script for evaluating alarms
Hello. I need to make a easy scalable soulution for alarm evaluation.
I want to use a GA named "VALUE1" and then evaluate it against a GA named "LOW1" and "HIGH1". If VALUE1 below LOW1, the LAL1 is to high and so on.
So the script part I can fix easily, but would it be possible to make a script that adds the other GAs as virtual GA, and automaticly adds the eventbased script to "VALUE" GA?
If I'm making any sense.. The GA's will be written to from a BMS system.
-Regards
