I asked for the 4g modem to be installed in the reactor, since a customer has only provided me with 4g sim, when the APN returns and the internet connects, I send the emails but I have an error in sending the SMS.
Does the SMS library also have to be modified in order to manage the new modem?
below the error reported in the offending lines
function sendsms(number, message)
require('socket')
client = socket.udp()
client:sendto(number .. ' ' .. message, '127.0.0.1', 12535)
This script has nothing to do with the SMS sending via modem it simply sends message to the resident script. Post your full resident SMS script and a screenshot from System config > Status > System status > Serial ports.
(31.01.2022, 15:30)admin Wrote: This script has nothing to do with the SMS sending via modem it simply sends message to the resident script. Post your full resident SMS script and a screenshot from System config > Status > System status > Serial ports.
resident sms
-- init
if not numbers then
require('user.sms')
require('json')
require('socket')
-- allowed numbers, SMS from other numbers will be ignored
numbers = { '3332958126' }
-- port number depends on modem model
comport = 'ttyACM3'
doreset = false -- set to true if USB reset is required before starting any communication
-- if SIM PIN is enabled, uncomment the line below and replace 0000 with SIM PIN
-- pincode = '0000'
-- name end not found, stop
if not pos then
return
-- get name part
name = cmd:sub(1 + offset, pos - offset):trim()
if mode == 'W' then
value = cmd:sub(pos + offset):trim()
if #value > 0 then
-- try decoding value
dvalue = json.pdecode(value)
if dvalue ~= nil then
value = dvalue
-- send to bus
grp.write(name, value)
-- read request
obj = grp.find(name)
-- object not known
if not obj then
return
-- send read request and wait for an update
obj:read()
os.sleep(1)
-- read new value
value = grp.getvalue(name)
-- got no value
if value == nil then
return
-- add object name if specified
if obj.name then
name = string.format('%s (%s)', obj.name, obj.address)
message = string.format('Value of %s is %s', name, json.encode(value))
modem:sendsms('+' .. sender, message)
-- incoming sms handler
handler = function(sms)
--alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))
-- sms from known number, call parser
if table.contains(numbers, sms.sender) then
--parser(sms.data, sms.sender)
-- check local udp server for messages to send
udphandler = function(server)
-- check for local sms to send
local msg = server:receive()
-- got no message
if not msg then
return
-- split into number and message
local sep = msg:find(' ')
if not sep then
return
--alert('sending sms: ' .. msg)
modem:sendsms(msg:sub(1, sep - 1), msg:sub(sep + 1))
-- handle data from modem
if modem then
if modem:run() then
udphandler(server)
--alert('SMS handler lost connection')
modem:reinit()
-- modem init
--alert('SMS handler init')
-- open serial port
modem = AT:init('/dev/' .. comport, doreset)
-- init ok
if modem then
-- set sms handler
modem:setsmshandler(handler)
-- send pin if set
if pincode then
modem:send('AT+CPIN=' .. pincode)
modem:read()
-- set to pdu mode
modem:send('AT+CMGF=0')
-- enable sms notifications
modem:send('AT+CNMI=1,1,0,0,0')
-- fixup encoding
modem:send('AT+CSCS="GSM"')
-- delete all saved messages
modem:send('AT+CMGD=1,4')
-- local udp server for sending sms
server = socket.udp()
server:setsockname('127.0.0.1', 12535)
server:settimeout(0.1)
--alert('SMS handler started')
-- init failed
--alert('SMS USB init failed')
-- init
if not numbers then
require('user.sms')
require('json')
require('socket')
comport = 'ttyACM3'
-- pincode = '0000'
if not pos then
return
-- get name part
if mode == 'W' then
if #value > 0 then
value = dvalue
-- send to bus
-- read request
-- object not known
if not obj then
return
obj:read()
os.sleep(1)
-- read new value
-- got no value
return
if obj.name then
-- got no message
if not msg then
return
if not sep then
return
if modem then
if modem:run() then
udphandler(server)
modem:reinit()
-- modem init
-- open serial port
-- init ok
if modem then
-- set sms handler
-- send pin if set
if pincode then
modem:read()
-- set to pdu mode
-- fixup encoding
-- init failed
return msg
end,
-- decode sender address depending on source type
decodesender = function(sender, ntype)
if ntype == 5 then
return AT.decode7bit(sender)
return AT.decodeswapped(sender)
end,
-- decode time in sms pdu
decodetime = function(timestamp)
local offset, year, time
time = os.time({
year = year < 70 and (2000 + year) or (1900 + year),
month = tonumber(timestamp:sub(3, 4)),
day = tonumber(timestamp:sub(5, 6)),
hour = tonumber(timestamp:sub(7, 8)),
min = tonumber(timestamp:sub(9, 10)),
sec = tonumber(timestamp:sub(11, 12))
}) or os.time()
return time
end,
-- convert swapped number to normal
decodeswapped = function(data)
local i, nr, len, buf
buf = {}
-- real byte length
len = math.floor(data:len() / 2)
-- read 2 bytes at once
for i = 1, len do
-- convert low byte to number
nr = tonumber(data:sub(i * 2, i * 2))
if nr then
table.insert(buf, tostring(nr))
-- convert high byte to number
nr = tonumber(data:sub(i * 2 - 1, i * 2 - 1))
if nr then
return table.concat(buf)
end,
-- convert from 7 bit char to 8 bit
from7bit = function(c)
if c < 128 then
return string.char(AT.alphabet[ c + 1 ])
return ' '
end,
-- converts from 7 bit to 8 bit
decode7bit = function(data, len)
local i, o, byte, prev, curr, mask, buf, res
-- convert to binary string
data = lmcore.hextostr(data, true)
-- init vars
o = 0
prev = 0
buf = {}
for i = 1, data:len() do
byte = data:byte(i, i)
-- get 7 bit data
mask = bit.lshift(1, 7 - o) - 1
-- get current chunk
curr = bit.band(byte, mask)
curr = bit.lshift(curr, o)
curr = bit.bor(curr, prev)
-- save bit chunk
prev = bit.rshift(byte, 7 - o)
-- add to buffer
table.insert(buf, AT.from7bit(curr))
-- every 7th step prev will have a full char
if o == 6 then
table.insert(buf, AT.from7bit(prev))
prev = 0
o = (o + 1) % 7
-- catch last char in buffer
if prev > 0 then
-- flatten buffer
res = table.concat(buf)
if len then
res = res:sub(1, len)
return res
function AT:init(dev, reset)
require('serial')
local t = setmetatable({}, { __index = AT })
t.dev = dev
while true do
if t:reinit(30, reset) then
break
if reset then
t:reset()
return nil
return t
function AT:open(timeout)
local port
while true do
if io.exists(self.dev) then
port = serial.open(self.dev)
if port then
break
if timeout then
timeout = timeout - 1
if timeout <= 0 then
return false
os.sleep(1)
self.port = port
self.buffer = {}
return true
function AT:reset()
--alert('modem reset')
os.execute('usbreset /dev/bus/usb/001/001')
function AT:reinit(timeout, reset)
local res
if reset then
self:reset()
res = self:open(timeout)
self.buffer = {}
return res
function AT:close()
if self.port then
self.port:close()
self.port = nil
-- read single line from port
function AT:read(timeout)
local char, err, timeout, deftimeout, line
-- default timeout is 1 second, converted to 0.1 sec ticks
timeout = tonumber(timeout) or 1
timeout = timeout * 10
deftimeout = timeout
-- read until got one line or timeout occured
while timeout > 0 do
-- read 1 char
char, err = self.port:read(1, 0.1)
-- got data
if char then
-- got LF, end of line
if char == '\n' then
-- convert to string and empty buffer
line = table.concat(self.buffer)
self.buffer = {}
line = line:trim()
-- return only lines with data
if #line > 0 then
return line
-- reset timeout
timeout = deftimeout
-- ignore CR
elseif char ~= '\r' then
table.insert(self.buffer, char)
-- read timeout
elseif err == 'timeout' then
-- other error
break
print('error', err)
return nil, err
-- blocking read until cmd is received
function AT:readuntil(cmd, timeout)
local line, err
timeout = timeout or 5
line, err = self:read()
-- read line ok
if line then
if line == cmd or line == 'COMMAND NOT SUPPORT' or line:match('ERROR') then
return line
err = 'invalid line'
-- timeout
-- other error
break
return nil, err
-- send command to terminal
function AT:send(cmd)
local res, err = self.port:write(cmd .. '\r\n')
-- write ok, get local echo
if res then
res, err = self:readuntil(cmd)
self:read()
return res, err
-- main handler
function AT:run()
local res, err, cmd, pos, sms
res, err = self:read()
if err then
return err == 'timeout'
-- check for incoming command
if res:sub(1, 1) ~= '+' then
return true
pos = res:find(':', 1, true)
if not pos then
return true
-- get command type
cmd = res:sub(2, pos - 1)
-- check only for incoming sms
if cmd ~= 'CMTI' then
return
-- read from sim
sms = self:incsms(res)
-- sms seems to be valid, pass to handler if specified
if sms and self.smshandler then
self.smshandler(sms)
return true
function AT:incsms(res)
local chunks, index, sms
-- get message index from result
chunks = res:split(',')
if #chunks == 2 then
-- get index and read from it
index = tonumber(chunks[ 2 ])
sms = self:readsms(index)
-- delete sms from store
self:deletesms(index)
return sms
-- delete sms at index
function AT:deletesms(index)
local cmd, res
-- send delete request
cmd = 'AT+CMGD=' .. index
res = self:send(cmd)
return res
-- read sms at index
function AT:readsms(index)
local cmd, res, sms
cmd = 'AT+CMGR=' .. index
-- no message at then index
if res == 'OK' then
return nil, 'not found'
Replace the whole sendsms function with this and check if it works. Also check if you have any messages in Logs.
local client, err = require('socket').udp()
if client then
client:close()
log('failed to created socket: ' .. tostring(err))
(01.02.2022, 12:18)admin Wrote: Replace the whole sendsms function with this and check if it works. Also check if you have any messages in Logs.
if client then
client:close()
You have the same code in the resident script twice, this can lead to errors. You've also commented out all alerts so there's no way of knowing if the script is working or not.
Replace your resident script with this and post what you get in alerts:
-- init
if not numbers then
require('user.sms')
require('json')
require('socket')
comport = 'ttyACM3'
-- pincode = '0000'
if not pos then
return
-- get name part
if mode == 'W' then
if #value > 0 then
value = dvalue
-- send to bus
-- read request
-- object not known
if not obj then
return
obj:read()
os.sleep(1)
-- read new value
-- got no value
return
if obj.name then
-- got no message
if not msg then
return
if not sep then
return
if modem then
if modem:run() then
udphandler(server)
modem:reinit()
-- modem init
-- open serial port
-- init ok
if modem then
-- set sms handler
-- send pin if set
if pincode then
modem:read()
-- set to pdu mode
-- fixup encoding
-- init failed
(01.02.2022, 13:35)admin Wrote: You have the same code in the resident script twice, this can lead to errors. You've also commented out all alerts so there's no way of knowing if the script is working or not.
-- init
if not numbers then
require('user.sms')
require('json')
require('socket')
comport = 'ttyACM3'
-- pincode = '0000'
if not pos then
return
-- get name part
if mode == 'W' then
if #value > 0 then
value = dvalue
-- send to bus
-- read request
-- object not known
if not obj then
return
obj:read()
os.sleep(1)
-- read new value
-- got no value
return
if obj.name then
-- got no message
if not msg then
return
if not sep then
return
if modem then
if modem:run() then
udphandler(server)
modem:reinit()
-- modem init
-- open serial port
-- init ok
if modem then
-- set sms handler
-- send pin if set
if pincode then
modem:read()
-- set to pdu mode
-- fixup encoding
-- init failed
For the problem of sending sms I solved with your help in 2 reactor out of 3, in the third with the same scripts, if I text the sms calling send it works, while if it is called from the script the alalrme event does not work, while the mails from the same script do
The alalrme event scripts I checked it are like in the reactor it works in, I'm getting lost and I don't know where.
I found the problem, the phone number had a space at the end for which it was not valid, now I try how to remove the spaces before and after, both for the phone number and if I can also for the email address so as to no longer have the problem.
