Threads: 15
Hi!
We have old WindowsMaster controllers with connected KNX equipment. The connected LM sees only sensors of a certain type (WET112), the rest of the equipment does not see and does not update. LM version 20200727.
Help me please. I have no more ideas.
Threads: 28
What do you mean by does not see? Do not receive KNX telegrams?
Threads: 20
It only does not work from LM to KNX equipment?
Does ETS telegrams work well?
It is connected by IP?
Threads: 15
Yes, only LM does not receive telegrams, old controllers work. We have 3 lines in 1.1.0, 1.2.0, 1.3.0. The sensors that the LM sees are from lines 1 and 2. The LM is connected via IP, on the same network as the router and old controllers, multicast IP. It doesn't matter what mode is selected TP-UART / EIBnet IP Tunneling / EIBnet IP Routing - the LM receives telegrams only from these sensors.
This is so strange, could there be a problem with the LM version? Or are filters installed somewhere?
sorry for my bad English
Threads: 15
No, this 1-3 lines only for old equipment. We want to use LM as a gateway and connect via IP. My question is, could this be related to the LM version?
Threads: 28
For LM KNX telegram is a telegram, it does not matter where it came from. Check filter table, src policy.
If KNX would be broken then everything would not work, not just a particular device.
