Loop through groupadresses to set alarm
    -- Comfort alarm for room 9. All adresses for room 9 = X / X / 9. -- Thresholds for alarm MaxCo2 = 800 MaxTemp = 25 MinTemp = 20 MaxHum = 60 MinHum = 40 -- Get co2, temperature and humidity values Co2 = grp.getvalue('12/1/9') Temp = grp.getvalue('6/1/9') Humidity = grp.getvalue('13/1/9') ComfortAlarm = grp.getvalue('25/1/9') -- Check if values are within the thresholds if Co2 > MaxCo2 or Temp > MaxTemp or Temp < MinTemp or Humidity > MaxHum or Humidity < MinHum then     -- Sets alarm on or off if ComfortAlarm == false then         grp.write('25/1/9', 1) else end else   if     ComfortAlarm == true then     grp.write('25/1/9', 0)   end end
Hey,
I have made a script to set a comfort alarm if Co2, room temperature or humidity is not within threshold values. This works fine.
The group adress structure in my project is that all adresses to one room = X / X / room number. So for the code above its a comfort alarm for room number 9.
Example Co2 in room number 9 is 12/1/9. Co2 in room 24 is 12/1/24. So main group and middle group is all the same in every room.
My question is if its possible to make a loop to run through every room checking the same adresses and setting the same alarm for each room?
So alarm for room 9 would set 25/1/9, and alarm for room 60 would set 25/1/60.
All help would be appreciated
(27.02.2022, 15:50)SennepKrem Wrote: Hey,
Are all the rooms in numerical order, following the xx/xx/room format?
This loop below would work if they are all in order, otherwise you may need a table to list all the rooms and iterate over that from the start to the end.
   -- Comfort alarm for room 9. All adresses for room 9 = X / X / 9. -- Thresholds for alarm MaxCo2 = 800 MaxTemp = 25 MinTemp = 20 MaxHum = 60 MinHum = 40 start_Grp = '1' end_Grp = '60' for i = start_Grp, end_Grp do -- Get co2, temperature and humidity values   Co2 = grp.getvalue('12/1/'.. i) temp = grp.getvalue('6/1/'.. i) Humidity = grp.getvalue('13/1/'.. i) ComfortAlarm = grp.getvalue('25/1/'.. i) -- Check if values are within the thresholds if Co2 > MaxCo2 or Temp > MaxTemp or Temp < MinTemp or Humidity > MaxHum or Humidity < MinHum then     -- Sets alarm on or off if ComfortAlarm == false then         grp.write('25/1/'.. i, 1) else end else   if     ComfortAlarm == true then     grp.write('25/1/'.. i, 0)   end end   end
Thank you! This worked just as i wanted. Very much appreciated!
