Javascript and Storage
Is there a way that I can read/write on Storage from JavaScript?
I would like to create a keypad for the security system and I want to temporally construct the pin on the Storage so I don't cause traffic on the BUS.
Thank you in advance
It's possible to use built-in pincode control as keypad input. In this example it attaches to an element with Additional class set to showpin. Clicking this element will show the pincode input. Once user inputs 4 numbers (length variable, adjust as needed) the pincode value is sent to 2/1/1.
Custom JavaScript:
$(function() {
  if (window.$E) {
    // override pin check event to allow custom check callback
    $E.pincode.off('check').on('check', function(event, control, pincode, data) {
      if (data.checkcallback) {
        checkPinResult(control, data.checkcallback(pincode, data));
      else {
        checkPinCallback(event, control, pincode, data);
    $('.showpin').off('vclick').on('vclick', function() {
      var length = 4; // pin code length
      showPincode(length, {
        checkcallback: function(pincode) {
          grp.write('2/1/1', pincode);
          return true;
        // not used, do not remove
        callback: function() {}
Thanks for the answer,
Is it possible to save it on Storage instead of writing it on an object?
Not possible directly. Why do you want to use storage? The pin script will send the whole code so you don't need to save it number by number.
